z06 4th gen wheels
Old Jun 19, 2008 | 07:01 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
z06 4th gen wheels
im about to get a set off this guy that has 18" z06 wheels that he had on his 2000 SS camaro, so i did the search and looked on the FAQ and it says to get 2.5 wheel hub spacer? i have spacer's in the rear already, the ones that go inbetween the rotor and the wheel its self so im wondering if thats good enough. has anyone done this particular swap or setup? or if there something i need to mod it with im lookin for a part name or # and/or site. thanks all.
Old Jun 19, 2008 | 07:19 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: z06 4th gen wheels
more next time but here check out SKULTE they make top quality ADAPTERS NOT SPACERS....they have what u need...http://www.skulte.com/
o yeah and u only should need 2inch adapters not 2.5
Old Jun 19, 2008 | 11:25 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
yea i did utilize the search, thing is theres always something new and whatnot, or something discovered i suppose...thanks for the info though. im gonna go with their 2" adapters but i dont understand i need a pair just for the rears? or for fronts also, if anyone has an idea.
Old Jun 19, 2008 | 11:35 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
youll need them for the front and the back....
Old Jun 19, 2008 | 11:37 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Depending on the offset of the rear ones, 2" may be too much.
I don't know the offset of the ones I had but with the LS1 rear end (same as having 2" spacers on each wheel), they stuck out a little too much.
18x9.5" front with 275/35/18 tires and 18x10.5" in the rear with 295/35/18
Old Jun 19, 2008 | 11:50 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
man thats some money right there! for all four. well thing is i dont have a LS1 rear and those pics are they with the ls1 rear? theyre not THAT bad, it looks pretty good, as long as the wheels dont rub the lip ya know. well if anything i can get the 1.7' adapters and if i need more room i can put a spacer on that as well? i dunno. i think im gonna have to play it with trial and error. i mean if i can bolt on those wheels from the guys 2000 SS camaro and drive around for the mean time until i get the adapters and what not, then thats cool. i think getting some measurements would improve a lot also...
Old Jun 19, 2008 | 11:58 PM
Stephen's Avatar
Car: 87 GTA
To run 4th gen wheels on the rear, you will HAVE to get the adapters or a 4th gen rear....which isn't a bad idea. Bigger/better brakes...better posit & no adapters.
For the front....The adapters will be reuired, no ifs, ands or buts about it.
So...4 adapters OR 2 adapers & a 4th gen rear axle.
Old Jun 19, 2008 | 11:59 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
u can't just bolt on the wheels and try them out without spacers, will not fit, i personally used 2" all around and had to pound in part of the inner fender wall as my 305's rubbed somewhat, i figured if ever i sold the rims having uniform 2" spacers front and back would be easier
Old Jun 20, 2008 | 06:02 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
My C5 wheels with 275/40 tires needed 2in spacers/adapters all around. No way they would have fit at either end without them. After I swapped to a 4th gen rear I ditched the rear spacers.
Old Jun 21, 2008 | 12:35 AM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
wait i thought spacers werent "safe" since the studs were too far from bolt thus weakening the load and whatnot. i think im just gonna go with the 2" adapters all around then, even though theyre like 150 a pair...does anyone know a place that has em a bit cheaper? if not, no biggie ill still have some beer money and cash for that 350 im about to pick up. also, the guy is sellin 18" inchers so will that have some bad wheel rub up front? i see that guy said something about poundin out some fender there, hey whatever it takes right??
Amillionoh7
May 24, 2020 08:01 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Oct 1, 2015 02:20 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
TMZIrocZ350
Exterior Parts for Sale
Aug 8, 2015 05:55 PM
