Hood won't line up....
Old Jun 21, 2008 | 07:06 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
I bought a plain jane stock hood to put on my firebird TA and am having some fittament issues. The front of the hood sticks up a bit at the nose
These areas here
My headlights are lined up with the fenders yet the hood sticks up in this area? How do the "pros" fix this issue?
It seems to me that you can apply some light pressure and "bend" that area to line up a little better..........would that be the way to do it?
This isn't my car btw......the batteries in my camera died and I needed something to give you guys a visual.....if it's your car I'm sorry
Old Jun 21, 2008 | 09:12 AM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Hood won't line up....
I'd play with the adjustments up front (those rubber hood stops) and lower them a little bit (they just twist like a screw). also does it line up good with the bumper cover? because if its high there too I'd play with the hood latch a little
Old Jun 21, 2008 | 09:16 AM
Car: 1971 Camaro
It lines up even at the center of the top of the bumper cover.....the hoods not even touching the rubber bumpers.....there's about 1/4" gap between the top of the bumper and the hood. But if I move it down to with the latch to even those points out there will be a dip in the center.
I'm going out in a second to play with it some more to see what I can do
Thanks for the quick reply
Old Jun 21, 2008 | 07:41 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
did you manage to get it any better?
Old Jun 21, 2008 | 07:46 PM
Car: 1971 Camaro
moved the front latch down a bit and got a happy medium, I think it'll be ok. Thanks forthe tip about the front latch....for some reason I didn't think about that
Old Jun 21, 2008 | 07:53 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
haha the only reason I thought about it is I just sprayed my engine bay and had to take the latch out, when I put the latch back in my gaps in the front became horrible! glad to help though
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
