single stage black layed,stripes layed, should i wetsand single stage before clear?
Old Jun 21, 2008 | 06:03 PM
tripingeorge3's Avatar
i have the single stage black done but i have alot of orange peel. i also have the huge grey stripes layed. should i wet sand the single stage first to remove orange peel or can i go ahead and clear coat then wet sand and be able to remove the orange peel by smoothig just the clear?
Old Jun 21, 2008 | 06:07 PM
Re: single stage black layed,stripes layed, should i wetsand single stage before clea
here's pics
Attached Thumbnails single stage black layed,stripes layed, should i wetsand single stage before clear?-picture-001.jpg   single stage black layed,stripes layed, should i wetsand single stage before clear?-picture-002.jpg
Old Jun 21, 2008 | 07:46 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
yuck! thats the reason I hate single stage so much, I sprayed a buick in black single stage and it was nothing but orange peel and dry spray. but to answer your question I'd wetsand that all out before clearing.
Old Jun 21, 2008 | 08:04 PM
Little Tim's Avatar
You need to wetsand. Then apply one more coat of black followed by the clear. If the single stage has orange peel the clear coat will not lay flat on top of it. Since you are painting stripes black base may have been a better choice. Your stripes look sweet!
Old Jun 21, 2008 | 08:20 PM
this was my first paint job. i have no more black. i'm just good with spray paint.so would it be good to wet sand it dull ,then clear. would it bring the shine back.
Old Jun 21, 2008 | 08:23 PM
Little Tim's Avatar
If you are out of black then lightly sand and clear. I suggested putting another coat on after sanding because to remove the orange peel you might break through the black. Give it a careful sanding and clear. The clear should be easier to spray and will lay out flatter for you.
Old Jun 21, 2008 | 10:50 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
another reason to apply another coat of black is wetsanding could leave scratches that will show through the clear coat so I'd be real careful when wetsanding that black
Old Jun 21, 2008 | 11:04 PM
what grit sand paper should i use?
Old Jun 22, 2008 | 11:08 AM
Little Tim's Avatar
If you have plenty of paint on it (at least 3 coats) use 600 followed by 1000. If you don't have that much paint on it then just use 1000. It will take you forever to use 1000 but you'll have less chance of breaking through. Don't use anything rougher than 600. Use LOTS of water when sanding. Good Luck!
Old Jun 22, 2008 | 05:04 PM
fronzoos's Avatar
Car: 1991 Pontiac Trans Am WS6
Engine: LSX
Oh my god! Sand it!
Old Jun 22, 2008 | 05:09 PM
MasterFab's Avatar
Car: 85 Berlinetta
Engine: 2.8
my advise......sand it all off.....primer....sand....paint....paint...paint....sand....clear....sand.....polish
Old Jun 22, 2008 | 06:29 PM
just sanded the hood. used 600 then to 1000 then to 1500 to make sure i wouldn't have any scratches show thru the clear. but did i go too far using the 1500. i have 98% of the orange peel gone. whats left is so little that it does bother me. you think the clear will hold to the 1500? oh by the way, the hood was the worst. the rest of the is nowhere near as bad.
Old Jun 23, 2008 | 07:30 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
if its enamel let it cure before you spray some clear on it
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
diana227vegas
Jul 8, 2016 12:27 AM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
Omega
LSX and LTX Parts
Aug 26, 2015 06:40 AM
