Whats the offset of 3rd gen wheels?
Old Jun 28, 2008 | 07:41 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Im looking in to gettting rims for my camaro cant find what offset they are and what not. these are the rims im looking at ARE-1056861
(summit) or this one ARE-1056865 summit as whell
are either of them right?
thanks in advance
Old Jun 29, 2008 | 08:58 AM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Re: Whats the offset of 3rd gen wheels?
i guess noone knows
Old Jun 29, 2008 | 09:13 AM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
Axle/Gears: fact G80 with GT4 3.73
4.75". the ones u want will fit.
Old Jun 29, 2008 | 01:44 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
alrighty thanks
Old Jun 29, 2008 | 02:27 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
Old Jun 29, 2008 | 03:35 PM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
dont no but i bought four and ahalf inch and they have plenty of room.i have heard of people using up to five inches
Old Jun 29, 2008 | 08:14 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
oh ok i was jsutworrried about that and if the holes where right too( didnt know what to call um)
Old Jun 29, 2008 | 10:10 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
You asked about the offset. And specifically, the offsets from the factory were 0(zero) for the front wheels and +16mm for the rear wheels for the 16" x 8" wheels.
But 0 will work for both, front and rear, making the rear wheels stick out about 5/8" farther than the front wheels, giving you a wider, better-looking stance, IMO. And using the same offset all the way around will make ordering simpler, and it also gives you the ability to rotate your tires down-the-road without having to pop the tires off the rims to do it.
And IIRC, the ARE Torq Thrust wheels can be ordered for any offset. So getting them in the size you want/need is simple.
And the correct bolt pattern you need is 5 x 4.75".
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Oct 1, 2015 02:20 PM
reiderz iroc
Aug 13, 2015 04:57 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
