im 17 & need advice/help for my z28!
Old Jul 11, 2008 | 02:24 AM
red84z's Avatar
Car: 84 z/28, 89 iroc-z
Engine: 305 H.O., 350 TPI
Transmission: auto, auto
Axle/Gears: 3.73's, 3.23's
okay to get straight to the point i got the 4th gen seats installed & now id like to try to instaill 91/92 "body kit" since im missing the lower front GFX
how hard is it to do & what all will i need to get off the 91/92 the GFX come from
i plan on swapping the nose, side skirts, rear bumper, & the lower quarter panel pieces. from what ive heard the nose is direct swap? & ill have to drill holes for the rest is it true?
& where can i get an "Aero spoler" at a good price besides ebay. all local junk yards didnt have any...
all help is appreciated!
Old Jul 11, 2008 | 12:44 PM
dsull357's Avatar
Car: 92 Camaro RS
Engine: 3.1
Re: im 17 & need advice/help for my z28!
Good luck on the Aero spoiler they are hard to find and the ones you do find aren't cheap. I am going to have to takle fixing mine.
Old Jul 11, 2008 | 01:24 PM
dollarbill425's Avatar
Car: 89 Camaro RS
The nose is direct the chin spoiler you'll have to cut slits in the fender by the turn signals everything should bolt up BUT,,, sometimes you'll run into some tweaks like just finished putting the aero gfxs on my 89, I didn't bother with the bumper or the rear quaters, and the rockers on the passenger side matched up perfect however, there is a bolt that goes through the rear section of the rockers on the older gfxs the newer ones have tabs so on mine I had to cut the tabs and drill a hole in the inside of the rockers insert a bolt then push the bolt through the pre existing hole inside the car by the backseats,,,the drivers side was off maybe an eighth of an inch so i drilled some holes on where the top of the rockers sit under the door, the door moldings was a direct fit as well(yes u will need the newer door molding so the doors open and close)... Its not that hard to do the switch really unscrewing and cutting a little bit of metal...
This will all make sense once you get into it, you'll want to take out the back seats and trim as well, to get to the nut for the bolt on the rockers... this is all if you have the same gfxs on yours as I do...
Old Jul 11, 2008 | 02:15 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
everything is pretty simple just lining things up will take more time then anything i just throw away a aero spoiler because it had a little crack in it probably repairable i knew i should've waited longer to toss it just got tired of it laying around
Old Jul 11, 2008 | 02:18 PM
Car: 89 Camaro RS
ah you suck
Old Jul 11, 2008 | 02:26 PM
mario82z28's Avatar
i know was cleaning out the garage and wasnt thinking i guess... sorry
Old Jul 11, 2008 | 02:36 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
I did the swap on my 83 Z. It is pretty easy but some modifications will be required. Make sure you get the brackets for the 91-92 gfx pieces. The front and rear bumpers will be a direct bolt on.
To use the 91-92 front gfx you will need to make two slits into the fenders. That can easily be done with a dremel. The side gfx bolt right on if I remember correctly. The door gfx pieces might require some enlarging of the holes that are already there. For the rear gfx, you will need to drill a new hole to mount them.
Old Jul 13, 2008 | 12:16 AM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
hey man its not to hard. Look online and in the junk yards for them i got one that i installed on my old camaro for $10! needed some sanding and paint. lloked great. Keep lookin man and you will find one. -Matt
Old Jul 17, 2008 | 11:47 AM
red84z's Avatar
thanks for the help, i did know the bumpers were direct bolt on but i was unsure of the front lower gfx piece & the ones on the lower quarter panels
i could have gotten a full 1991 RS "body kit" for $175 had everything but the car got crushed a few days later my friend got the complete interior for $125
& i finally fount a "Aero spoiler" in a junkyard in knoxville it was off a purple 91 z28 & only cost me $40 plus tax
i am still looking for a 91-92 z28 hood with the blisters on it so that i dont have to hunt for the blisters after i get a hood
im considering going with the 85-90 nose & GXF so i can get done quicker
i plan on pulling the 305 H.O. & dropping a lt-1 or a 383 stroker in it further into the future. but whats a good exhaust to put on my car?
im considering the flowmaster 40 series because it sounds good but its too damn loud inside the car. also my car will NOT have a catylic converter put back on
Old Oct 9, 2008 | 08:10 PM
red84z's Avatar
got 2, picked a purple one up for $50
and a white one up for $35
both are primered now though..
Old Oct 10, 2008 | 08:12 AM
Car: 89 Camaro RS
wanna sell one?
Old Oct 11, 2008 | 10:53 PM
red84z's Avatar
not quite yet, i got one on my 84 but im still debating puting the other on my iroc
ill let ya know if i do though.
Old Oct 12, 2008 | 01:17 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Lets see some pictures of them, and lets see some progress with your cars...
Old Oct 30, 2008 | 02:45 PM
red84z's Avatar
well i dont feel like posting pics in here, just go to my cardomain page & check em out lol
http://www.cardomain.com/id/asimp90
Old Oct 31, 2008 | 02:16 AM
nimrod_sixty9's Avatar
Car: '91 RS Camaro
Engine: 5.0 TBI
Transmission: Manual
Axle/Gears: 3.08
Ive got the FM 40 series on my 305 with no CAT, sounds amazing. Ppl comment on it all the time. Youll like it
Old Nov 3, 2008 | 12:20 PM
wulfgar the pen's Avatar
Car: 1988 sc camaro, 1986 IROC
Engine: 2.8 v6, 305 tpi (for now)
Transmission: automatic, auto( for now)
only r1cers leave their cat off, its bad for the world and its illegal
Old Nov 3, 2008 | 08:48 PM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Yea, Im a complete r1cer because I have no CAT.
Old Nov 3, 2008 | 10:06 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
classic industries has them brand new for 199$
Old Nov 4, 2008 | 10:40 PM
cmccully04's Avatar
Harry's u pull it in PA has 3-4 of these 2 look pretty good, I think they said 200 for the complete kit
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
David Frans
Oct 31, 2015 08:12 PM
Night rider327
Oct 9, 2015 09:25 AM
z28joe2
Sep 28, 2015 05:54 PM
