T-Top trim removal?
Old Jul 15, 2008 | 06:02 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
T-Top trim removal?
on my Iroc i got a t-top with that iron trim that goes around the glass and one that doesnt. anyone ever removed it before and how?
Old Jul 15, 2008 | 08:10 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: T-Top trim removal?
HUH? Sorry but I'm not following what you mean.
Old Jul 15, 2008 | 08:48 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
sorry for the confusion. on the t-top glass around the 3 glass edges there is a metal trim shaped like a "U" and the edge of the glass sits in it to prevent it from chipping i think. the trim is on the t-top and NOT on the body. i want to take it off because my drivers side top doesnt have it and the passenger side does. dont know how to take it off.
Old Jul 15, 2008 | 09:08 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
I think your best bet would be to find a new piece for your other T-top. Just a hunch. Unless you like to get wet?
Old Jul 15, 2008 | 09:33 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
no it has nothing to do with the seal cause the one without it doesnt leak. when you take off the t-top it comes with it. its molded on the edge of the glass. think someone coulda put it on there?
Old Jul 16, 2008 | 12:28 AM
EvilCartman's Avatar
Car: '82 Z28
I'd find more of the trim to protect the glass from being chipped on the edge and possibly getting shattered.
Old Jul 16, 2008 | 07:36 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i have an 83z parts car , thats the kind of t tops it has . i think the early ones had the metal trim and hooks to secure instead of sliding rod to secure . i think if you tried to remove it you might be asking for a leak . good luck .
Old Jul 16, 2008 | 08:27 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
thanks guys thats probably what ill do. do you know where i could get it?
Old Jul 16, 2008 | 11:33 AM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
Transmission: Manual
I have the same style on my 83. The channel is plastic and is no longer available from GM. I have look and look and can not find any sources, I’d like to replace mine also. Its held on with weather strip adhesive, it is possible to pull it off but will most likely tear. I have tried to get it off many parts cars with little success.
Old Jul 16, 2008 | 04:24 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
My 87 doesn't have that trim piece. The edge of tempered glass is sensitive and will shatter easily if hit just right. The trim was probably to protect against that. The newer ttops might have some edge protection built into the glass that helps prevent shatter when hit. Tempered glass is strong because it has an internal pressure pushing out, while the outside is pressing in. The edges of the glass cooled more quickly allowing for less temper. Hitting the edge just right will shatter the glass, where an equal blow to the center may not do a thing.
Old Jul 16, 2008 | 06:59 PM
sounds like someone replaced one of the tops on your car with the wrong style.
Like scottmoyer prev. said,his 87 doesn't have that glass edge trim,so your 89 shouldn't either.
Can you post any pics of it?Scott could probably tell ya in a heartbeat if its the right piece and if its not, be able to tell ya what it came from.
Check his car out!That thing is GORGEOUS!
I have seen it in person.
Old Jul 16, 2008 | 09:34 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
I personally dont have a digital camera but i could get one from a friend. ill post when i get a picture. thanks guys
Old Jul 17, 2008 | 11:46 AM
Romilin's Avatar
I just bought a 92 v6 t-top and it has metal black painted trim running along the edges of the top also. But the top is plastic and not glass....... I recently saw a glass top without the trim. So I personally was assuming that the glass ones did not come with the trim at all. But that was just me thinking out loud
Old Jul 17, 2008 | 06:02 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
OK guys i think i figured it out. 82 to 85 camaros had the trim. newer models (86-92) did not. i also found out that the glass (other than the tint) SHOULD be the same through all the years. Since my trim is so cracked anyways i am going to try to remove it and then clean the glass. it should remove fairly easily since its loose anyways. Like Scott Moyer said that the edges could be very easily shattered ill have to be very careful when i remove them. Ill tell ya how they turn out!
Old Jul 20, 2008 | 07:16 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
My 85Z doesnt have that trim on the t tops.
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
