Paint pimples
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Paint pimples
My car was painted some years ago and had been in storage for about 12 years after it was painted.
I noticed the paint started pimpling all over in the last 2 yeats....can anyone tell me the reason for this and what if anything I can do (wetsanding,etc) to get rid of the pimples or will it require repainting.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Paint pimples
Yeah, I was thinking the same. I would hope not, because that is a PITA and requires a repaint after it is repaired. What areas is the damage?
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Paint pimples
rust or water, if the bondo got wet it can hold moisture and release it later.
If its rust, they won't pop, poke one and see. If its hollow it was water, or might still be full of water. Use a pin.
Car: 89 T/A
Engine: LB9
Re: Paint pimples
There's really nothing to pop....it's like the car has goosebumps or something.
I took a pic....have a look and let me know what you think.
Definately not rust....car is excellant shape....just appraised at $13K.
Car: 89 Iroc Z
Engine: 5.0
Re: Paint pimples
I was expecting something different, Thats not paint pimples, looks more like razor bumps... I was gonna say orange peel aswell after see'n the pic, How about WetSanding and Buffing it?
Car: 89 T/A
Engine: LB9
Re: Paint pimples
I'm going to try wetsanding and see what happens.
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Paint pimples
try some clearasal lol j/k
my Pontiac 6000 had those too. turned out that the paint job wasnt done properly >
Car: 89 T/A
Engine: LB9
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Paint pimples
hmm, I'm guessing thats lacquer paint and its blistering up now, its just a form of how lacquer paints shrink over time, it will need to be repainted. in the pics you can see orange peel but if you look closely you'll see little bumps that look like stubble, Im guessing thats what hes talking about.
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
Re: Paint pimples
Looks to be an extreme case of solvent pop. That is when the solvents from a primer, sealer, base coat, etc.. tries to evaporate after after the top layer has cured. If it is base clear you can try to wet sand it but in your case I doubt it will work. Your gonna end up sanding through the clear most likely to remove those bumps. Its is a single stage, no clear coat, then you might get away with sanding and buffing. That is if there is enough color to not sand through. Id start with something heavy, prolly 1000-1500 grit and then finish up with 2000 grit. After you do this your going to have to buff it. Not by hand, youll be there all day and it wont turn out well. An orbital wont work for this you need a rotory variable speed buffer. This is the scarry part and if youve never done it before you might want to let a profesional do this. You have to be very care full not to burn through. Dont leave it in one spot for very long, always buff off panel edges not into them. Its easy to do once you get the hang of it. If you need some help or more info on how to do any of this PM me. Just to put you at ease, that is deffinatly not rust
Matt
Matt
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Paint pimples
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Paint pimples
Matt
Matt
I really have no doubt its due to lacquer based paint, my teachers corvette stingray has this same issue, it looks like it has water droplets on it when your standing 10 feet away, but once you get closer you see the paint has little pimples in it.
Car: 89 T/A
Engine: LB9
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Paint pimples
That cheap paint you talk about was standard for GM in the 80s, there is nothing a fancy 2 stage paint can do that a single can't if you treat them the same. But folks don't, you can color sand and clear a single stage paint, they been doing it sonce the dawn of hotrods. If you were born after your car was made, your a putz who knows nothing.
THe best rod jobs were your so called cheap single stage black laqcure so deep you could walk into it.
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Paint pimples
yeah ok...
and I'm not disagreeing at all that lacquer finishes may look nice, but honestly they're out dated, the products of today are so much safer to spray, they will hold up much better then lacquer finishes and they'll look just as nice when layed down correctly.
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
