window adjustment?
Old Aug 11, 2008 | 06:25 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
window adjustment?
I'm having leaking problems where water is getting in on the front part of the windows where it lines up with the a-pillar/windshield. its a very small but very frustrating gap.
i can even hear the air scream in when i'm on the highway
i took my doors apart to replace window strips and to replace badly tinted/stratched glass and i also took out the triangle part that the window slides into in the front of it for when i painted the car
I cant remember and i dont want to take apart my door again unless i get a yes here.
but is the triangle part of the window/door assembly adjustable back and forth? as far as towards or away from the a-pillar?
its either that or i need to do some custom work to beef up the weather stripping to push up and fill in that gap.
and the weatherstripping is new and its only happening with my passeneger side
Old Aug 12, 2008 | 05:45 PM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
Re: window adjustment?
im having the same issue but mine is on the back part of the windo
Old Aug 12, 2008 | 07:55 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
https://www.thirdgen.org/windowadjust
J-money
Jan 4, 2019 09:45 AM
Fronzizzle
Sep 8, 2015 12:10 PM
scottmoyer
Sep 7, 2015 07:06 PM
SG91camaro
Sep 5, 2015 10:27 PM
