wetsanding and buffing questions???
Old Aug 22, 2008 | 07:58 PM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
Well...just painted the camaro, and I decided I would try to wet sand some of it to see if i could clean it up a bit...
I've never wet sanded before so I had 2000 grit and wet sanded a spot and it turned light gray, freaked me out, but I now know its normal, so I went and got some turtle wax rubbing compound and scratch remover but it didn't make it go back to black...I was doing it by hand but it never got darker???
Should I get a different compound, also is the only way to do it with a buffer? I'm probably just going to fix the spots I did though because I do not have a buffer...
Old Aug 23, 2008 | 12:26 AM
mbolte's Avatar
Car: 1987 Camaro
Re: wetsanding and buffing questions???
babump
Old Aug 23, 2008 | 09:06 AM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
If you are wetsanding...you need a buffer, it's that simple....I don't think anything by Turtle wax will be a true "compound..." It may be a "cleaner", I could be wrong....
Look for something by 3M or Meguiar's.
You should be able to get the gloss back by had on the spots if you used 2000g but you will really need some elbow grease...
Old Aug 23, 2008 | 09:12 AM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
you will need a buffer.
I used turtle wax rubbing compound followed by turtle wax polish, heres some pics if you don't mind.
before
after
Old Aug 23, 2008 | 01:05 PM
mbolte's Avatar
Car: 1987 Camaro
cool thanks guys, i might have to invest in a buffer and some better compound and do the whole car to clean it up a bit
Old Aug 23, 2008 | 04:31 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
i know it is not the greatest but harborfreight has some cheap electric buffers. and ya i would go to a body supply shop and get some good 3m compounds and whatever they recomend for a specific pad for the compound you get!!
Old Aug 23, 2008 | 06:06 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
well i assume you know the process here. You wet sand than CAREFULLY buff with a buffer (not a grinder) than apply and buff with the random orbital buffer. So I always use two types.
Old Aug 23, 2008 | 10:27 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
yeah man you have to have a buffer!An orbital or hand waxing ain't gonna cut it.
Hawk312
Aug 22, 2017 08:55 PM
project89
Sep 24, 2015 06:38 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
