affordable single stage
Old Aug 26, 2008 | 02:54 PM
blackblazer717's Avatar
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
im looking for a somewhat affordable single stage paint supplier, and the correct sealer primer to go with it.
any help would be awesome, even better would be a company who sells the facory colors, bright teal met. or semi-metallic blue.
thanks
Luke
Old Aug 28, 2008 | 04:07 PM
camarobird92's Avatar
Car: 95 Z28, 92 Camarobird
Engine: 410 rearwheel hp LT1, TBI 305
Transmission: 4L60E, 700R4
Axle/Gears: 4.11's, Whatever BS GM put in it
Re: affordable single stage
Affordable paint???? LOL That's HILARIOUS!!!!!!
Old Aug 28, 2008 | 05:15 PM
madhatter's Avatar
go to any body supply shop in your area. they can walk you through what works with what and what companys have a one stage paint in the color you want. i used a ppg bc/cc system. avenger blue pearl mixed with cobalt blue metallic. it is an awesome color, i got primer, base, and clear with all the reducers for $660. it really isn't that expensive to use a bc/cc system.
ppg, dupont, limco all make single stage paints in a variety of colors. you really need to look at the paint books that the stores have. they will set you up with all of the other things that you will need for that system. also FYI when looking in the books for your color make sure you walk it outside with the book and look at the colors in the sun. the colors are really different outside in the sun
Old Aug 28, 2008 | 06:08 PM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Hit up your local NAPA and get the house brand (Martin Senour) in an Acrylic enamel. Solid colors you can get under $200.00 for everything. Metallics can get a bit pricey though.
Old Aug 28, 2008 | 06:21 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Something I havent heard anyone say here is that Single stage metallics require more control, as well as a more controlled environment. You need a little experience at spraying to lay down a nice single stage metallic paintjob...Especially acrylic enamels... and your garage probably ain't the place to do it... You don't buff a single stage metallic...
Old Aug 28, 2008 | 07:16 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
http://www.tcpglobal.com/restoration...surethane.aspx
Old Aug 28, 2008 | 07:50 PM
Opher's Avatar
Car: 92 Jamacia Yellow Formula 350
look into Kirker Automotive Finishes.
for the money these guys can not be beat. Its no topshelf stuff, but its not like the bottom of the barrel nason, omni either. Most colors can be had and you can use a stabilizer to turn there acrylic enamel into a basecoat. They have a lot of different products as well.
Transtar makes some good refinish products as well.
Old Aug 28, 2008 | 08:10 PM
87GTAj's Avatar
Car: 87 Trans Am GTA
Engine: 5.7L TPI
thanks
Luke
Can't find much cheaper than this - at this price, you could repaint every two years and still be ahead of the game a decade later:
http://www.paintforcars.com/enamel_paint_kits.html
Teal metallic/Daytona metallic are close.
Old Aug 28, 2008 | 10:13 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
if they have any in stock
Old Aug 28, 2008 | 10:29 PM
87GTAj's Avatar
Engine: 5.7L TPI
??? I just finished using their BC/CC Candy Apple Red Metallic. Got here in under a week, worked out great. $190 shipped.
Old Aug 29, 2008 | 11:56 AM
Matrix Systems products are really great for the price also...
Old Aug 30, 2008 | 08:04 AM
Car: 92 Rs
thanks alot guys, ive been doing reasearch for some time now, i just wanted a finishing decision, i like what they offer on tcpglobal.... and on ppg, but ppg is way out of range.
thanks
luke
Old Aug 30, 2008 | 08:25 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
tcp global has an ebay store which seems to be cheaper than their website
http://myworld.ebay.com/ebaymotors/t...autobodydepot/
Old Sep 2, 2008 | 12:29 PM
Car: 92 Rs
sweet dude, but i think they get you there on shipping....
Old Sep 2, 2008 | 03:45 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
eastwood I believe sells single stage paints for like 120 a gallon, one of my friends painted their muddin truck with it.
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
tmork454
Sep 29, 2015 06:33 PM
dusterbd
Sep 29, 2015 08:40 AM
