91 Camaro z28 rear end destroyed
Car: '84 Z28
The extent of the damage is still unknown, but i was wondering, if it was minimal, could i replace the rear end with a 84 z28 rear end? thanks
casey
casey
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: 91 Camaro z28 rear end destroyed
by rear end do you mean rear axle or rear bumper. iether way they should be interchangable i would think. esspecialy the bumper
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
yes, one from a fourth gen will also fit and would be a better choice IMO
Car: '84 Z28
okay, to clear things out, it might possibly be the rear end, and ive heard i can replace that (axle, etc.), but its the body i'm worried about, assuming the frame isn't completely F'd up would i be able to replace the whole back window/trunk area and rear side panels and lights and bumper, how hard would it be if i could?
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I am pretty sure it can be done, but it will be EXTREMELY hard to do. You would have to cut the rear of your car and a donor car off and then weld the rear from the donor onto the front part of your car.
The best way to do it would probably be to leave as much bracing as you can (that is not damaged) and just drill out the spot welds holding it all together. Then come in with the new section and weld it into the supports using plug welds where the spot welds were.
I would really try to avoid cutting the car apart because you will run into a lot of work and a lot of things that are not easy to do. Plus you have to make sure you get the new piece lined up perfectly.
Car: '84 Z28
okay, well since no one has straight out told me 'no' it sure as hell makes me feel better lol. i have access to pretty much all the tools i need and what you told me sounds realistic titan, thanks, more opinions are welcome keep them coming.
wow this is alot more complicated then i originally thought lol any pictures of the damage in question? but the quarters and hatch and bumper are interchangeable as far as i know the only thing is the rear bumper cover will be a different style from 84-91
Car: '84 Z28
I should be getting pictures soon, maybe by tomorrow but only if i can find my digital camara. Its out at a friends house and the fool works all the time, and his phone is disconected or something, so i'm ganna run over after he gets out of school to talk to him
anything that you guys have to say about this is appreciated, i have to get on now but i'll be on again tomorrow
thanks!
thanks!
Last edited by 10secondhopeful; Sep 3, 2008 at 04:28 PM. Reason: Automerged Doublepost
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
my uncle use to have an 86 camaro...actually it was an 86 and an 88 i believe...anyways the back end on the 86 was toast so my gramps cut the back end off the 88 and welded it to the 86 and from what i know no problems car was great...im talking from rear hatch back...so it can be done...but i dont think it would be very easy...trying to get the two half's lined up properly then all that welding...
it really depends on what you are working with. my car was hit by a semi and it was a lot of work to fix. i had to replace the passenger quarter, the back peice behind the tail lights, and the force of the hit pushed the drivers quarter out. now even though it was the other side of the car that was hit the drivers poped out about a half to three quarters of an inch. its not really hard to do it but i hope you have lots of spare time because body work in general is time consuming. now if you add body panel replacement on top of that you are in for a long project. good luck
Car: '84 Z28
Okay thanks for the input guys, i have to talk to a friend about the weilding but it could be possible, and time isn't a problem, i have alot of that lol
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
It is always possible if you have $$$. All I have to say is good luck with the body work. I'm trying to learn how to do that now.
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
novaderrik
Aug 10, 2015 12:44 PM
