floor pan repair or replace?
Old Oct 3, 2008 | 09:29 AM
phillyterror's Avatar
Car: 85' T/A
Engine: 5.7 350
Transmission: 700r-4
Axle/Gears: 9-bolt Borg Warner
This is the F-body I owned, both had this problem. This first was a 89 firebird; which all floor started to rust and fall apart. But fortunally; I came across a 85 T/A That didn't seem to have much rust! But put a more beefier engine in it, trailing arms broke on the passenger side. also got rust on the driver floor where the you would put your feet at?
Mechanically! the car is sound, but should I replace the whole floor/ or should I look for another T/A. also I wanted know? Is hardtop stronger than T-Tops?
Thank You!
F-BODY Forever
Old Oct 3, 2008 | 09:42 AM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Re: floor pan repair or replace?
if the rest of the floor is good then just patching one part should be fine. And hard top cars will have less flex than t-top, but all of them should have subframe connetors
Old Oct 3, 2008 | 10:22 AM
Car: 85' T/A
Engine: 5.7 350
thanks
Old Oct 3, 2008 | 04:12 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I had a hole about 1.5" diameter.. It was where the seam seal is on the firewall, so I POR 15'd it, and went on a seam sealing rampage.. it was hot.
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
MY87LT
Aug 17, 2015 08:43 AM
mizz0313
Aug 12, 2015 06:45 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Amillionoh7
Aug 7, 2015 01:24 PM
