I need some ones opinion on body work
Old Nov 11, 2008 | 11:34 PM
beswa's Avatar
Hi, i have an 86 camaro that i am doing some body work on. The body is in generally good condition, the one problem that i do not know how to handle is the front window sill is rusted badly in a few spots. dose anyone have any experience with this kind of repair
thanks Dave
Old Nov 12, 2008 | 10:27 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: I need some ones opinion on body work
what do you mean my window sill? Do you mean on the door or the a-pillar? can you post a picture of it so we can see how bad it is?
Old Nov 12, 2008 | 10:43 AM
Joelfke's Avatar
Car: 1991 Camaro RS Conv
Engine: 305 V8
if youre not a welder i would say to fiberglass it after you sand it down to bare metal then sand the fiberglass paint over it
Old Nov 12, 2008 | 11:17 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I had rust under my windshield. It appeared the window replacement company basically wire-wheeled the area. Then put por15 on it.
Biggest problem, once rust is started. The only way to stop it is to cut it out and replace it.
Old Nov 12, 2008 | 03:00 PM
madhatter's Avatar
depending on how bad it is and where it is located, depends on what you will have to do. if it is just under the glass it could be fiberglassed over, easy way out, if it is rusting into the A Pillar i would start to cut and replace. if it is a big hole rotted all they way through i would cut and replace. if you are worried about making patch panels the easiest way is to get donor pillars out of a junk yard that are in good shape, skin them and put in place of the bad metal. i guess what im saying is how much do you like your car and how nice do you want it to be. there are many levels of body work. there is the half *** looks okay job where rust comes back in a few years / months. on the other hand there is the i spent time doing it right and hope fully it wont happen for another 20 years job. i really depends on time and money, and what you want the car to be when your done.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
