frame protection
Old Nov 13, 2008 | 08:45 AM
84 camaro z28's Avatar
Car: 84 camaro z28
Engine: 5.7 carbed
Transmission: turbo 350
frame protection
Hey i was wandering since im going to be putting in a 383 with around 430 horse how to i keep the frame from bending because i know some people who took there cars to the track and bent their frame on the first run. So i was wandering how to keep this from happening to me. Thanks
Old Nov 13, 2008 | 10:34 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: frame protection
That doesn't really happen.
You can put in subframe connectors, if you want to stiffen up the car in general. But these cars don't have "frames" per se, so you could bend the unibody, but without full on race slicks, upgraded suspension parts, all you'll do is spin anyway....
Old Nov 13, 2008 | 11:40 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
...Unless its really rusty.
Old Nov 13, 2008 | 12:28 PM
kcb37's Avatar
If you have a 383, I wouldn't stomp on it untill you have subframe connectors. I would also have them welded.
A roll cage will help too.
Old Nov 18, 2008 | 11:23 AM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Do you have T tops? If you do subframe connectors are almost a must if your upgrading the HP and Torque. Better safe than bent.
Old Nov 18, 2008 | 03:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
hardtop, t-top, no top, it doesnt matter, all thirdgens flex too much and will benefit from a good set of SFC.
Old Nov 19, 2008 | 11:00 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
what he said
Old Nov 20, 2008 | 07:31 PM
Car: 84 camaro z28
Engine: 5.7 carbed
ok so im not really understanding what your getting at by sub frame connectors the kid i bought the car from origanally but this rigged up metal beem from the rearend too up front right under holding the tranny up so is this somthing like your talking about
Old Nov 21, 2008 | 10:17 AM
jamon8's Avatar
Engine: 350 tpi
thats a torque arm and if its not right could give you some issues
what we are talking about ties the front and rear subframes with metal tubes or boxed frame extentions
Old Nov 23, 2008 | 01:48 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Look in the suspension forum and search for subframe connectors. There's lots of info there.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
83RDRACR
Mar 26, 2016 08:13 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
