so, im painting.
Old Nov 18, 2008 | 08:31 AM
92WhiteZ28's Avatar
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
so, im painting.
I'm not actually painting the car yet, well, i actually just need to paint the hood and wing to match. I have sanded the hood and spoiler down, and im ready to paint, but i have never done any of this before, and i dont know what im doing. What kind of primer should i use? I'm going with a dark grey, or black color. How many coats do i need? Any suggestions would be great. Thanks!
Old Nov 19, 2008 | 11:22 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: so, im painting.
sealer primer
you dont need a bunch of base but put the clear on heavy so you can sand and buff
Old Nov 19, 2008 | 05:33 PM
92WhiteZ28's Avatar
ok, where is the best place to get this, sealer primer?
Old Nov 19, 2008 | 05:37 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
You can get it at pep boys advance im actully doing this to but to the front bumper and hood. I think they have a orange color and a grey one. Im doing 3 coats of primer, wetsanding, then mabye 3 of base wetsanding, then alot of clear and wetsanding hopeing it turns out good. Wetsanding with 2000 grit paper.My brother did his hole car like this and it looked pretty good, but it wasnt shiney im going for really shiney then might do hole car if it looks good enough.
Old Nov 20, 2008 | 11:04 AM
jamon8's Avatar
Engine: 350 tpi
sounds like you need to make a new friend at the place where they sell paint
Old Nov 20, 2008 | 09:23 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Look for an autobody supply store in your area. They'll have everything you need and lots of good advice.
Old Nov 22, 2008 | 10:41 AM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
most auto part stores have a piant section with a specific paint guy that can mix any color you need. they dont just try to sell you the most expensive products especially if you tell them it is your first time. be honest with them, give them a budget of both money and time and they will help you out from start to end. but you should always get more than one quote, not because some places have higher mark-ups but because everyplace sells different brands. one place may have cheap paint that requires a expensive primer and the next place could have good paint with a cheap primer. get a quote on the whole project!!
Old Nov 25, 2008 | 11:18 PM
allenfre's Avatar
Oowee! I suggest you to have someone at your back while doing these if your really not sure of what you are doing. Anyways, I prefer to have a couple of (Primer/base/top) coatings. I used white for my last primer.
SDIF
Mar 13, 2013 12:04 AM
T1m3_Sh1ft3r
Jan 21, 2010 02:44 AM
krismiller34
Sep 14, 2009 01:01 PM
chas0218
Aug 29, 2009 02:00 PM
