Evoluzione panel joint ideas
Old Nov 20, 2008 | 11:53 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Getting back to my Evoluzione project. I have a butt joint where the front fender is supposed to mold into the rocker. I had to cut this apart when I installed my vertical doors. Seems I should keep this removable for service. My first thought was finishing the edges and with a bracket behind the rocker have 3 or 4 visible dzus 1/4 turn fasteners visible on each side. Anybody got any better ideas?
Old Nov 20, 2008 | 12:02 PM
Stephen's Avatar
Car: 87 GTA
Re: Evoluzione panel joint ideas
Pics of what your talking about? But it sounds similar to what I've seen on a Pro Street 55 Chevy. The rear tires were tucked so high up, even when jacked up, the tops of the tires were still in the fenders.
So he made part of the side of the quarter removable.
Old Nov 20, 2008 | 05:50 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
I think you should keep it smooth. I know what your saying but the only reason I can think of to service it would be for the antenna. Unless you get hit.......
Old Nov 20, 2008 | 08:06 PM
ACCLR8N's Avatar
I'm worried about servicing the lift struts hinge adjustments.
Attached Thumbnails Evoluzione panel joint ideas-fender_joint.jpg   Evoluzione panel joint ideas-door-open-struts.jpg
Old Nov 20, 2008 | 11:00 PM
UDAMON's Avatar
Car: Mazda Protege5
id mold a lip on each piece and bolt them together on the inside. definitely keep it serviceable.
Old Nov 21, 2008 | 06:46 AM
ACCLR8N's Avatar
I like that idea. Simple L-brackets behind the panel and I'd be able to adjust the alignment easily.
Old Nov 22, 2008 | 08:49 AM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
What UDAMON said. From what Iv'e heard about these doors they are always needing readjusted.
Old Jan 6, 2009 | 12:02 PM
ACCLR8N's Avatar
Hope this was what you had in mind. I'm happy with it anyway.
Attached Thumbnails Evoluzione panel joint ideas-rocker_plate.jpg   Evoluzione panel joint ideas-fender_rocker.jpg
Old Jan 6, 2009 | 05:08 PM
UDAMON's Avatar
Car: Mazda Protege5
that looks great! Nice work!!
Old Jan 7, 2009 | 10:38 AM
Engine: 400 and 350
Very nice. You should do the same thing to the rear quarter part. Mine cracked back their from jacking up the car stressed this point over a period of time and cracked the part that you mold together. What you done with the front part would look nice bark there and match the front.
Old Jan 7, 2009 | 11:24 AM
ACCLR8N's Avatar
Man, you don't want me to ever finish this car!
My passenger side split along the rear of the rocker I thought because I bumped my hoist backing in without mirrors. The LH side I noticed 2 nights ago a tiny hairline crack. I was thinking I had too much material in the joint and was going to redo it. Based on your input I'll add flanging it the same as the front to my list. Thanks for the input.
Old Jan 9, 2009 | 08:27 AM
1LOMARO's Avatar
Car: 89 Camaro, 94 z-71,98 Camaro
Engine: none, 350 tbi.sixxer
Transmission: none, 4l60e,auto
Axle/Gears: none, 3.73
I agree on the brackets on the backside ...it does look good. As far as finishing our cars...... ARE WE EVER FINISHED? LOL
Old Jan 9, 2009 | 10:17 AM
Engine: 400 and 350
Nope, never finished. Even when everyone thinks it's done, back in the garage we go. Also the longer it takes everyone to finish theirs the more rare mine is complete.
redmaroz
Apr 25, 2017 07:14 AM
fbirdroller
Sep 2, 2015 10:27 PM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
z28addict8490
Aug 7, 2015 08:48 PM
MENINBLK
Aug 5, 2015 11:58 PM
