Front Clip / Bumper
Old Nov 24, 2008 | 04:10 PM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
Front Clip / Bumper
I finally got a parts car and it's being a bitch to take the bumper off... Do I need all the bolts and the absorber guard? When I took the sides of the ground effects off the bolts snapped 2 on each side.
Old Nov 24, 2008 | 05:53 PM
toomany's Avatar
Re: Front Clip / Bumper
I've found it easier to take the headlight bar off with the bumper. But that's just me. IIRC there are a few bolts under the plastic shroud in front of the hood latch.
FWIW: Every time I've tried to take a chin spoiler off, I've broken atleast one of the studs. Most of the time it's two or three that break. I usually make a new stud plate with some threaded rod and some flat stock.
Old Nov 25, 2008 | 12:46 AM
robster66's Avatar
Engine: 305 T.B.I.
I don't know how to do that.. lol
Old Nov 25, 2008 | 12:59 PM
toomany's Avatar
Take the light bar off? Or the stud plate?
The light bar is only a couple of bolts in the center. Once you take them off (allong with the ones in the fenders) the whole nose will pull off.
Stud plate is easy. Get some threaded rod and a piece of flat metal. Tack weld the rod to the flat stock. It usually takes me more time going though my scrap pile to find a good piece of metal, than it does to make it.
Old Nov 25, 2008 | 01:34 PM
robster66's Avatar
Engine: 305 T.B.I.
To make the stud piece for the sides of the nose clip.
Old Nov 25, 2008 | 04:05 PM
robster66's Avatar
Engine: 305 T.B.I.
Can't I just get a piece of metal and drill 3 holes in it than put 3 bolts and nuts? I don't know what kind of metal but wouldn't this work?
Old Nov 26, 2008 | 05:49 PM
robster66's Avatar
Engine: 305 T.B.I.
On the 87 camaro where the ground effects came from on the fender theres 2 bolt holes and on my 92 theres 2 slots. Does that make any difference?
Old Nov 27, 2008 | 01:08 AM
toomany's Avatar
I've never dealt with 91-92 GFX, but have heard they mount differntly. I heard it was the door/rocker pieces that needed some new holes. Maybe someone else can help.
Old Nov 27, 2008 | 01:13 AM
robster66's Avatar
Engine: 305 T.B.I.
Another thing I wanted to know is do I have to use the plastic pieces off the actually metal bumper?
Old Nov 27, 2008 | 11:17 PM
toomany's Avatar
The impact absorber (black honey comb thing)? It seems to me that when I swapped over to the 88 nose on my 83, I had to trim it a little bit. I ended up just taking it off. I'd think the 85+ would be the same, maybe with the exception of Sc's. If you're swapping between simular years, you should be fine.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
dag19
Aug 26, 2015 10:22 AM
mikey8494
Aug 22, 2015 07:57 PM
