two types of front aero gfx's
Old Dec 1, 2008 | 11:03 PM
88_thirdgen's Avatar
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
is there two different types of (front lip) aero ground effects. the reason i say this is because my friend has a 91 and his (lip) aero ground effect in the center looks like it goes down flat. i have seen others, same aero ground effects that stick out from the middle why is that?
Old Dec 1, 2008 | 11:09 PM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: two types of front aero gfx's
yep 85-90 was one kind then a differnt one for 91-92
Old Dec 1, 2008 | 11:15 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
no no..... i know that... what i am asking is that his looks different than other aero style ones from the center part
Old Dec 1, 2008 | 11:20 PM
Kandied91z's Avatar
possibly remake or fixed improperly. there should only be one gm style, they weren't made long enough to be produced by other companies at the time to have variety.
Old Dec 1, 2008 | 11:25 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
this is what i mean, look at it from the center and it is completely flat..even mine(blue) sticks out more from the center and its non aero
Attachment 167876
Old Dec 1, 2008 | 11:27 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
look at pick and you will see what i mean. looks good when you look at it from the front but you look at it from the side and its flat
Old Dec 1, 2008 | 11:31 PM
Car: 1992 Camaro RS
Engine: 305 TBI
ima go with bad repair for that iv never seen one with that before
Old Dec 1, 2008 | 11:33 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
looks strange right??
blue91z28cam's Avatar
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
I cant even see the picture..bummer
Old Dec 1, 2008 | 11:37 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
Old Dec 1, 2008 | 11:38 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
can you see it now??
Old Dec 1, 2008 | 11:40 PM
yep..and it looks like that gfx has just kissed too many curbs...I got a 91 Z and its seen its share of driveways and stuff but it doesnt look at all flat...
Old Dec 1, 2008 | 11:44 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
from the center part it looks flat.i mean c'mon mine is non aero and from the center it sticks out more... wish i had better pics of his car . i am going to look for a better one
Old Dec 1, 2008 | 11:53 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
blue one looks like it sticks out alot moretwo types of front aero gfx's-lip-2.jpg
and his flat even the air pockets look bigger on the blue one... the whole gfx looks bigger overall
Old Dec 2, 2008 | 12:01 AM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
anything??
Old Dec 2, 2008 | 01:16 AM
SmokeShow's Avatar
Car: 1988 IROC Convertible
The blue one is on grass and doesnt have a license plate but they are the same
Old Dec 2, 2008 | 06:14 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
they're both equal, one has just been worn down by wind and driving... I'll bet the ones that stick out more have lower miles...
Old Dec 2, 2008 | 06:29 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
might be..... but they do look different..... maybe when he had his car repainted they didn't pull it out??
also another reason i think they are different is because i saw another 91 rs and that gfx looked the same (flat).. then i look at the 92'S camaros and they stick out from the middle way more
Last edited by 88_thirdgen; Dec 2, 2008 at 06:32 PM. Reason: Automerged Doublepost
Old Dec 3, 2008 | 12:00 AM
SmokeShow's Avatar
hahahah im telling you guys they are the same. The blue one looks bigger because of the colour, the fact that the license plate isnt there and that its sitting on grass. Cars look so much better when parked on grass
Old Dec 3, 2008 | 06:46 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
As was stated, the red cars front end has seen too many curbs and it has gotten misshaped. If you take his GFX off and lay them flat on the ground, his will touch the ground at center and the sides will be off the ground. It looks to be a good inch shorter than it should be because of the reshape.
Old Dec 3, 2008 | 07:33 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
could it be fixed??
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
formula_novice
Sep 5, 2015 03:58 AM
LittleFranks
Aug 20, 2015 03:55 PM
