Largest tire for OEM Rims??
Old Dec 11, 2008 | 08:19 PM
sid2007's Avatar
Car: 1985 Trans Am
Engine: 5.0 TPI
My friend is wondering what is the largest tire you can put on the OEM rims for his camaro, his dad has 295-50-R15 on his and he dont think they will work. He has a 1988 Camaro RS with the V8 TBI. Thanks
Old Dec 11, 2008 | 08:20 PM
Twin_Turbo's Avatar
Re: Largest tire for OEM Rims??
295s barely fit on an 8" wide rim, they will never fit a 7" wide rim.
Old Dec 11, 2008 | 08:24 PM
sid2007's Avatar
Car: 1985 Trans Am
Engine: 5.0 TPI
He was hoping for getting something like 265 or 275's to fit would they?
Old Dec 11, 2008 | 08:36 PM
Twin_Turbo's Avatar
Nope, the 295s fit on the 15x8 wheel because of the sidewall height (and they look like balooons), the larger your rim, the lower your sidewall and the less excessive width (or too narrow) is tolerated. My guess would be 255 would be the max. For 265 you'd need an 8"rim, probably even 8.5 (minimum approved rim width). Check with tire manuf. Their spec sheets should list approved rim widths.
Old Dec 20, 2008 | 11:14 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
i have personaly had 275 70? on mine in my sig i kinda liked the way they looked
crap just saw the date
Last edited by 91camarosRS; Dec 20, 2008 at 11:15 PM. Reason: Automerged Doublepost
Old Dec 21, 2008 | 03:26 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I've had 275/50/15's on the stock wheels, and actually still do. A set of 275/60/15 should also work just fine, but definitely no more than 275 for those 7" wide wheels.
Old Dec 21, 2008 | 03:38 PM
alscamaro89's Avatar
Car: 89 iroc
Axle/Gears: posi
i have 235/60/R15 so they are a little lower profile and a little wider and i like em not too expensive either.. have bfgoodrich radial T/As so like 85 a piece for this size
Old Dec 21, 2008 | 08:59 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Exactly, 235-60-15 is the largest tire you can get on a stock 15x7" wheel and still be considered "safe".
A true 295 tire needs about 9.5" to work right.
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
