A little bit of body work
Car: 1987 z28
Engine: 305tpi
Axle/Gears: 2.73 posi
Well the 87 had a few blemishes as seen in picture 1. I decided to strip it and attempt to paint it. Started it off with a paint scraper which worked great on the smooth parts since the paint was chipping.
Car: 1987 z28
Engine: 305tpi
Re: A little bit of body work
Its my first attempt at body work/painting. The first picture is after i hit it with 80 grit, and i decided to shave off the from emblem (opinions welcomed) i covered up some chipping on the plastic.
picture 2 is the emblem shaved off
picture 3 is the nose where it had damage from scraping. it was missing a nice 1X1.5 piece
Car: 1987 z28
Engine: 305tpi
pic 1 is the front, shows the shaved emblem and the repaired nose. taped up fog lights
ran to homedepot real quick for some primer, sprayed this in a few mins so its still fresh when i took the picture
Car: 1987 z28
Engine: 305tpi
got a close up on the nose and the front side again. i got alittle bit more minor dings to repair. and then im going to paint the front end with the color red included as attachment 3
tips and opinions are welcomed
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
looks like you have taken on a good project . remember , clean , clean , clean , between applications . a good finish depends on good prep work . good luck . keep us up dated .
Car: 1987 z28
Engine: 305tpi
Thanks, as for the cleaning is soap and water fine?
Here are a few pics of the dried primer this morning. The darker parts is dew from a cold morning
grease and wax remover is always a good thing to use also.
what did you use to fill the emblem? if you used body filler be aware it may shrink a bit. they make a two part epoxy for repairing urathane for like what you are doing and it works great.
Car: 1987 z28
Engine: 305tpi
i used resin on everything. after a little searching on the forums i found out the epoxy would be the best
Terrell351
Jun 13, 2021 01:13 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
