Sealing a window..
Old Jan 6, 2009 | 09:55 PM
JD_87Formula's Avatar
Sealing a window..
My backwindow is letting water through the liftgate.
Can anyone recommend a substance I can use to seal the tiny little space that the water is getting through?
It's where the glass meets the metal on the bottom of the glass piece, if you were looking at it standing behind the car.
Old Jan 6, 2009 | 10:15 PM
Mathius's Avatar
Re: Sealing a window..
It's not leaking through the latch, it's leaking through where the glass meets the deck lid?
IIRC that piece is bolt on and probably just needs a new seal.
Mathius
Old Jan 6, 2009 | 10:22 PM
Yes, that's what I mean. Where the glass meets the part of the liftgate, I guess you would call it a deck lid. I don't think it is bolt on, however. I took the trim off the latch and it didn't seem like it was but then again, I was not looking for it.
Anyone confirm this?
Old Jan 7, 2009 | 06:44 AM
Mathius's Avatar
Well there's no structural support for the decklid, i.e. metal, you can tell that just from pictures, unless there's two thin strips around the glass. Either way, the deck lid has to be fastened directly to the glass somehow or it would just flop down.
Either the deck lid is sandwiching the glass, or it's bolted to it somehow (or both.)
Quick fix you could dry the area real good and run some clear silicone, but I'd try to fix it properly if it was me.
Hopefully someone else will chime in.
Mathius
Old Jan 7, 2009 | 04:35 PM
popballz's Avatar
Car: 89 firebird
there is like 6 nuts that hold the glass to the deck lid.
Old Jan 8, 2009 | 01:07 AM
Tehsocks's Avatar
Car: 85 Camaro Z28
Engine: 6.0L LS
Transmission: T56 Magnum
I had this problem and i just put a little line of weatherstirpping adhesive inbetween teh glass and deck lid on the exterior,
i made sure i pushed it in there with a scraper. and it hasnt leaked since.
We've had major rainfall (over 130mm over the past 2 days) and my trunk is the only dry part of the car
Old Jan 10, 2009 | 10:28 AM
userchemical's Avatar
Car: 1984 Camaro Z28
Axle/Gears: 4th gen auburn 3.42 disc
this is the last 3rd gen i restored.
you just unbolt the deck lidl from the glass, remove the old silicone, clean everything, put new silicone down and align your hood bolt it tight. DONE.
Old Jan 10, 2009 | 10:30 AM
Old Jan 10, 2009 | 10:39 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
thank you for all the detailed pics!
Old Feb 23, 2009 | 08:12 PM
Good pics. I got all but one of those nut/washer things out because it was rusted to the deck lid.
Any ideas on how to get it out? I tried hammering the s*** out of it, several wrenches, and whatnot. No luck.
Old Feb 23, 2009 | 08:18 PM
popballz's Avatar
Car: 89 firebird
for some reason, some of my bolts just spun with the nut attached to them? anyways i used a saws all to cut the bolt off
Old Feb 23, 2009 | 08:31 PM
Well, that won't help much when I go to put everything back together.
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
