build sheet decoding
Old Jan 23, 2009 | 02:15 PM
mr. matt's Avatar
I have a build sheet for my 91 Formula. Does anyone know what box on the sheet would have the exterior paint code? The car is a dark grayish blue color. I have not yet seen one this color, and it is factory paint. thanks
Old Jan 23, 2009 | 02:51 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: build sheet decoding
build sheet as in paper? or do you mean the RPO code sticker? i got a few build sheets from various thirdgens i found over the years i can look, but the paint code will be on your RPO code sticker witch should be located in the center console or rear storage compartment lid and is located at the bottom and should start or look like
"BCCC WA-" also i believe theres a paintcode taged to your radiator support but im not sure
Old Jan 23, 2009 | 03:39 PM
mr. matt's Avatar
Yes, build sheet as in the paper found in the car. The car itself is not here with me, so I can't look inside at the RPO stickers, but I do have the build sheet here and figured it would have the info I seek. thanks
Old Jan 23, 2009 | 07:27 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Box 79 should say color and have the color code. Unfortunately, the buildsheet doesn't have the paint code.
Old Jan 23, 2009 | 08:38 PM
mr. matt's Avatar
the #79 box just has a number 87 in it. It does not say the paint color either.
Old Jan 23, 2009 | 10:27 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
87 ... The car must be gunmetal metallic. But you still may need to look at the rpo sticker to find the correct color code. It could be wa9243 or wa9536.
Old Feb 7, 2009 | 05:12 PM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
Could you post a scan of your buildsheet for us all to see what one actually looks like?
Elephantismo
Feb 13, 2019 12:51 AM
Magman
Aug 2, 2016 08:32 PM
Jorlain
Oct 8, 2015 01:57 AM
F-body-fan
Sep 24, 2015 08:29 AM
gta892000
Sep 16, 2015 12:37 AM
