Finally picked up an 87 carbed car
I wanted a carburated third gen, preferably an Iroc because i had owned 3 of them previously. I finally found something i could deal with, plus for $200 running and driving i couldn't really go too wrong. It had been sitting by a garage for 5 years and the owner finally parted with it. A guy i know bought it put a fuel pump in it and drove it about 500 miles before i picked it up.
All i know is it's an LT with some crazy after market ground effects, carbed 305, t tops, and it is factory yellow which i think is the last year for that. I'm gonna put my 383 and 400 turbo in it sometime this summer. I bought doors, fenders, front bumper and ground effect, rear bumper, and a Harwood lift off hood today for a little under $600. The parts are perfect since they came off of a car that was completely restored then never hit the road due to lack of time.
Giant cheater slicks on the rear mean no traction whatsoever so that's where it will sit until i have time to winch it a bit farther.
I've never been a yellow fan but unless someone comes up with something else it will be yellow. Do you think i should try to sell the ground effects and bumper covers? I'm definitely getting rid of the wheels and tires but i don't want to trash the ground effects if someone might be interested in them.
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Re: Finally picked up an 87 carbed car
Not a bad buy! How's the undercarriage? I'm liking the tails but not liking bumpers. Personally, I would hold onto it for a little while and see if anyone likes them. Where you guys from any how?
PS. Welcome to TGO!
PS. Welcome to TGO!
I'm in Northeast Ohio. The undercarriage is nice, it was stored on concrete so all the rust is where water pools and i already took care of those parts today by buying replacements. The bottoms of the doors and the bottom rear of the front fenders are shot but no big deal to replace. The bumpers kind of grew on me but they're arent my style. I'm aiming more for this.
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
man you got *****. looks like alot of work ahead of you. on another note can someone clear this up for me? the headlight buckets are black and its a base model. i always thought only the z28s got black buckets
I'm quite happy with it because i'm doing it as a summer/dragstrip toy. It's not going to be a flawless showcar but it will be a nice driver for those sunny days. I own too many cars as is so i really wanted something to play with.
I could be wrong too, but I thought all of them had black headlight buckets, at least after a certain year, may have been all third gens though.
Anyway, dosen't look to bad. I would have done it for 200. Sounds like you have a plan.
For paint, I don't really like yellow either. Red generally any shade looks good, light metalic blue, black, dark purple, with silver stipes.
i remember reading somewhere that gm gave the z28 and the z28 only black headlight buckets to make them easily identifiable to the public. may not be true but but i did read it somewhere maybe it was on tgo. and +1 on ditchin the yellow
Finally warmed up and i got a couple days off so i made some progress. I was happy just to have my wheels on it but i got more than that done.
I need to finish bolting the fenders on, lower airdam, and mount my hood. Then i can replace the rear bumper and get it painted. The antenna hole is shaved so for now i have my antenna inside the fender. I mostly use my Zune for music anyway so reception isn'a a big deal.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
congrats on the progress, lookin good. Can't say I care for the graphic on the door tho.. glad to know it will be going away
The graphic is really well done, airbrushed, but it's not my style either. The hood also has graphics on it but no big deal to sand them down. The car i got my parts from was local and had never seen the road after it was restored. I got everything i needed from one car and it was all like brand new, very cheap also. I only have about $500 in all my parts including my lift off 4" Harwood cowl hood.
The doors need everything but the rods and linkages put in but that's not a problem. I'm just swapping my stuff into them. I drove it down the road the way it sits and it wasn't too bad.
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Looks good and affordable -the best projects usually are!
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
looks like the car you got parts from was sunset mettalic! I say you do your hole car that color!!
does the rear hatch work?
keep us up to date on this project!
I'm curious, why did you specifically want a carbed car? It wouldn't seem to make much of a difference to me if you're just gonna swap in a different engine anyway..
Paint wise mine will end up the same scheme as yours only yellow and black if i go two tone. It is staying yellow though.
I wanted the carbed motor for the mechanical fuel pump which means i don't have to put a fuel pressure regulator on when i swap motors to another carbed motor. It also means a heck of a lot less wiring to get rid of later.
I'm hoping to get some more done Monday, supposed to be off but that's always an iffy situation. I'm going to get the rear bumper changed, hopefully the side skirts, and the front airdam. If i get that stuff done i will be driving it to work at least once by the end of the week. I'm dying to drive it more than a couple hundred yards.
I ended up getting called into work but i managed to get the front airdam mostly on, couple bolts still need installed but i ran out of time. I also test fit the hood so i took a couple pics. Next day off new calipers and pads.
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
