Help 1 eyed Formula
Help 1 eyed Formula
ANYONE HAVE ANY SUGGESTIONS ON HOW TO GET MY DRIVERS SIDE HAEDLIGHT TO CLOSE.PASSENGER SIDE WORKS FINE AND SO DID THE DRIVERS SIDE.NOW I CAN'T GET THE DRIVERS SIDE TO CLOSE EVEN USING THE MANUAL DIAL.....PM ME
THANKS,
GEOFF
THANKS,
GEOFF
Re: Help 1 eyed Formula
it the motor is running, but wont close/open
you should try this
http://hardwayracing.com/89gta/hlrepair/hlrepair.htm
and you can just use some rubber hose for the bushings
you should try this
After I posted this I went out (4hrs) later and pushed the button firmly in the cener and they both went down without issue. I am guessing it is the switch any comments?
Car: 87 GTA
I'm betting it is the Headlight Control Module, not the switch itself.
Are you working on a 3rd gen? Or the 4th gen in your sig pic?
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
what year is it? they changed the wiring design I believe in 86 or 87 to a solid state unit... if it's the later solid state design, the unit has a square black plastic case and is mounted right near the window wiper motor. The design will determine how you go about diagnosing the problem.
Car: 1984 Trans Am
that would have the solid state controller.... sorry, but I only know the wiring setup for the earlier style with 3 relays.
Axle/Gears: 3.45, 3.27, 3.27
There were also two different headlight control modules used on our thirdgen Firebirds. 1987-89 model years use one module. 1990-92 (actually all the way through 2002) used the other. They look identical on the outside.
Lon
Lon
Linson
Oct 1, 2015 09:50 PM
