Rear steel bumper!!!
Car: 84 S/C
Engine: 84 305 H.O.
Transmission: 700 R4
Axle/Gears: 3:08
O.K. My bumper is rusted out beyond repair. I have a parts car with a rust free bumper on it. I tried to get the nuts off the bolts but they came loose and backed off a little then the whole bolt turns. I think the bolts used by the factory are carriage bolts. I've tried everything to stop them from turning so I can get them off!!!
My question is has anyone ran into this problem? Does anyone have any ideas that I could try? Any help is welcomed.
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Rear steel bumper!!!
break out the cutoff wheel and cut the bolts
Car: 84 S/C
Engine: 84 305 H.O.
Axle/Gears: 3:08
Thought of that but there is no room to get one in there. Also can't get to the bolt heads. Sorry, I should have put that in my first post. Don't really wanna break out the tourch but maybe thats the only way. I hope not! Thanks for your input.
Car: 1985 Pontiac Trans Am
just took mine off today. U need to use an air rachet to spin the bolts faster. Use a prybar to hold the back of the bolt if it still spins.
Yeah, you really only have two options there, break the bolts, or press something against the carriage bolts to keep them from moving. I'm guessing that your bolts are spinning because the surrounding metal is rusted out? If that's the case, see if you can use a punch and a hammer and just bust the bolt right through bumper from the nut side.
You're just gonna scrap it anyways, right?
Mathius
Mathius
Car: 84 S/C
Engine: 84 305 H.O.
Axle/Gears: 3:08
Mathius
Mathius
Thanks, Guys
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Yes. just did mine also. Use a flat prybar to hold the square part of the carrige into the square slots. Then take a air rachet and spin away. When i took mine off, there are little pieces of thin steel with a hole and bent "threads" that hold the bolt to the crash bar.
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
These are a PITA to remove. I was able to cut mine off and breakoff the top bolts where you cant get a wheel into
I had to do that on my '89 Ranger when replacing the transmission crossmember. It had big round factory rivets, and I just ground them down and used a punch to push them through.
Mathius
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
