how do i fix my doors?
Old Feb 13, 2009 | 11:54 AM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
my doors sag and its annoying. i have broken every handle at least twice. i have already replaced hinges and it still does it. the bodykit on the botom of the door is scraping on the car body and it all looks bad how do it fix this problem? im tired of fixing broken handles,however i can do it in notime now, and telling ppl to lift on the door to open
Old Feb 13, 2009 | 12:06 PM
PURPLEFORMULA's Avatar
Car: '89 Formula Firebird
Engine: LSX-451 / 705HP
Axle/Gears: Moser Ford 9" with 4.30
Re: how do i fix my doors?
Loosen the bolt to the door hinges and have someone lift up on the door before you tighten them so when he lets off the door it will be level. What is happening is that the door sages alittle on the hinges new or old and you are not compensating for that. I hope this fixes your problem.
Eric
Old Feb 13, 2009 | 01:23 PM
george 88gta's Avatar
The other thing you need to check is to see if the hinge pin bushings are worn/broken. To check, lift up at the rear of the door. If it moves up and down, the parts are worn and need to be replaced. If you are lucky, you can just buy new pins and bushings (NAPA has them as well as many of the aftermarket places). If they are worn, adjusting the door wont last long, if at all.
Old Feb 13, 2009 | 07:32 PM
Car: 02wrx/88 rs
i tried adjusting with no sucess. i replaced bushings. but i can remember i couldnt get a rench in there for one. and another when i did loosen it wouldnt move(door) also if anyone has like technical article or pics would help me. or others that have this problem
Old Feb 13, 2009 | 08:48 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Dang, I remember a kit, I thing that I found it post of here that was make to fix the sagging doors. though i'd just post this link up. If I run across the kit I'll post it up.
Old Feb 13, 2009 | 09:20 PM
Car: 02wrx/88 rs
so bend it back? lol i rememer trying to use a floor jack to try to do that once
Old Feb 14, 2009 | 06:58 AM
Here is the kit. You can also try, top down solutions, to see what Lon has available.
http://www.hawksthirdgenparts.com/br...r-Pin-Kit.html One other thing to check is the window adjustment. If it goes up too far it will bind in the upper weather stripping. Lower your window and see if problem goes away. If it does, then check window adjustment.
Old Feb 14, 2009 | 07:41 AM
Car: 02wrx/88 rs
yeah thats the kit i baught. and it still does it
Old Feb 14, 2009 | 02:47 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
There are two reasons why the bottom of the door scrapes on the gfx. One is the hinge pins and bushings are worn out allowing the door to sag. The second reason is that the HEAVY and long door has bent the hinge. If your hinge pins and bushings are worn you need to replace them first (as you've done, hopefully correctly). If your door still drags on the GFX, then the hinge is bent. You have two options to repair it. You can have the door hinges re-bent at most auto body shop. Or you can buy a door alignment tool and do it yourself. I sell the EZ-Store door alignment tool. I only wish I'd discovered this tool before I bought the one made by MAC tools.
http://www.top-downsolutions.com/pro...products_id=95
Lon
Old Feb 14, 2009 | 03:10 PM
popballz's Avatar
Car: 89 firebird
Lon
would that be the same as just using a floor jack at the end of the door?
but i would assume the tool would be more professional?
anyone know how must a body shop would charge to do this?
Old Feb 14, 2009 | 03:35 PM
lonsal's Avatar
No. A floor jack will move up the door and the entire car body. This tool acts as a lever which is a force multiplier. The end of the tool rotates on the latch pin. There is a latch pin on the tool which latches into the latch of the door. There is a hex-shaped pin on the tool that you attach a socket to along with your breaker bar to put the leverage to bend up the door. It takes quite a bit of force to re-bend the door hinge. A floor jack won't cut it.
Lon
Old Feb 14, 2009 | 04:14 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
I hate trying to diagnose things from pics. It looks like your fender may be out of alignment at the door. It could be the door or the fender it's hard to tell. Maybe the fender and gfx are up from being put on a lift or jacked up under the fender. If the door is rubbing on the ground effects in the front that could be part of the problem.
If the pins and bushings are good and the door still sags, like others have said it's time for an adjustment. If you don't have the tool shown you can use a regular socket ... pretty big like 1" or so. Open the door and place the socket in the lower hinge (to raise the back of the door) between the 2 heavy hinge halves that come together when you close the door. Then close the door gently on the socket. Depending on the size socket you use the door could be open 6 inches to a foot or so. But you don't want it open too far. When you have pressure on the socket push the door closed some more as you lift up on the back of it. Go easy. It's better to do it twice than to over do it and try and undo it. If you did do the upper and lower hinges equally you would effectively be moving the door straight back and that can cause issues to so go easy. You are bending things so take it easy.
If you have your door aligned, the window isn't an issue, and things still don't close right you may need to adjust your striker. If it's pulling the door down when you close it move the striker up a little. And it's also adjustable in and out. The striker may also have shims (washers) behind it. It needs to fit in the latch in the right spot. If the striker is too far out it will drag on the inner part of the latch and if it isn't far enough out it will hang up on the other part. When you're done give everything a shot of white lithium spray grease. Good luck.
Old Feb 14, 2009 | 11:12 PM
Car: 02wrx/88 rs
sorry thats jsut my sig. but thanks for trying to see whats wrong. the socket thing sounds easy enough but... lol can you snap some pics to explain? i think i got it but i need dummy proof lol
Old Feb 14, 2009 | 11:48 PM
Car: 86 T/A
Engine: 5.0 TPI
Ok pay attention ... lol. I used a blue glass thing that was handy. I'm not going out to the shop to get a socket. It's cold ... and dark out there and something might get me! Use a socket ... not a handy blue glass thingy. Blue glass isn't very strong.
Put your SOCKET like this so it will contact the two heavy edges of the hinge when you close the door on it. If the socket is small it can be a tight squeeze trying to hold it in and close the door. I forgot how much room there was in these doors so you may even want to use a deep socket. Or a really big blue glass thingy. NO ... I didn't mean that!
Old Feb 16, 2009 | 12:39 AM
Car: 02wrx/88 rs
so lift on the door while doing that? or is that bending that out?
Old Feb 16, 2009 | 01:25 AM
Car: 86 T/A
Engine: 5.0 TPI
Yes lift on the door as you put inward pressure on it. Doing this in the lower hinge will raise the back of the door. Doing the upper hinge will lower the back of the door. Remember be gentle. Thats a long door and you can get a lot of leverage on it. It's better to do it a little bit twice than it is to go to far and have to undo it.
Old Feb 18, 2009 | 01:46 PM
blackroc68's Avatar
Also check the hinge that stays on the doors. A new hinge will only help if bushing holes are elongated if the part of the hinge that stays on the door gets stretched the pin will move and the bushings will where out.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
