A-Pillar and Door Panel retaining clips / christmas tree part numbers wanted
Old Feb 25, 2009 | 04:10 PM
87350IROC's Avatar
Car: 87' IROC
Hi all. I want to replace all of the plastic hardware for my A-pillars and Door Panels. I have tried ones from Autozone ect, and they never seem to be quite the right size. Does anyone have GM part numbers?
Looking for:
A-Pillar
Top Clips - should be 20462090
Side "christmas tree" clips - ???
Door Panel
Thanks,
John
Old Feb 26, 2009 | 07:47 AM
SpeedJunkie's Avatar
Car: 88 IROC
Re: A-Pillar and Door Panel retaining clips / christmas tree part numbers wanted
I also would like to get these too
Old Feb 26, 2009 | 12:28 PM
Chase0224's Avatar
Car: 1985 Trans Am
Engine: 305 TBI
as would i, im missing a bunch and some are busted. Ill see if i can help you guys out and run to the GM dealership tonight and have them look them up.
Old Feb 26, 2009 | 02:04 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I've got some at junkyards, but they are so brittle they break when you pull them out.
Old Feb 27, 2009 | 11:44 AM
87350IROC's Avatar
Car: 87' IROC
I feel your pain. That why I want to do it right this time and buy new GM parts.
Old Feb 27, 2009 | 12:42 PM
Chase0224's Avatar
Car: 1985 Trans Am
Engine: 305 TBI
didnt make it to the dealership last night, but i am tonight for sure right after school, ill let you guys know.
Old Feb 27, 2009 | 01:33 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Are these those white fuzzy looking things with huge heads on them? Half-turn into the panel and then press fit it into a hole to retain the panel?
If so, you can get them at ACE Hardware, unless you're into NOS/original, etc. They're over in the nut and bolt section.
They also carry a lot of the misc panel screws and under hood nuts and bolts.
Old Feb 27, 2009 | 03:46 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
just go to advanceauto or autozone
they have like 5 in a pack done deal
Old Feb 28, 2009 | 09:50 AM
Chase0224's Avatar
Car: 1985 Trans Am
Engine: 305 TBI
went to the GM dealership and got some, they are pontiac 77 and higher years, panel christmas trees, and boy are they expensive. 2.97 for one! I got a guy ive known and bought parts off before and he gave me 15 for 5 bucks, so i lucked out. There are a couple numbers on the box and ill post them all up.
he said he uses this number to find them but he doesnt think its the part number: 2224
And the number i believe is the part number: 3065575
I compared them to the ones i have and they look almost exactly alike, same diameter and length and such.
Old Feb 28, 2009 | 10:58 AM
87350IROC's Avatar
Car: 87' IROC
Guys I'm aware they sell them at auto stores. Like I said, I've yet to see ones at the stores that actually fit correctly. They usually just break.
Chase,
That part number doesn't show up on gmpartsdirect. It should be an 8 digit part number. Thanks to posting your results. I'll head to the dealer today and see what I can find.
Old Feb 28, 2009 | 11:03 AM
87350IROC's Avatar
Car: 87' IROC
Oh, also, does anybody know how many are needed to replace them all?
Old Feb 28, 2009 | 11:13 AM
87350IROC's Avatar
Car: 87' IROC
Hey guys check out this site.
http://autoclipsonline.com/GM_door_retainers.htm
Looks like 20374473
I still can't find that part number on gmpartsdirect though.
Old Feb 28, 2009 | 11:17 AM
87350IROC's Avatar
Car: 87' IROC
Check this site too.
http://www.scottsupply.net/Catalog/c..._fasteners.htm
I checked 12337920. And it checks out on gmpartsdirect. 86 cents each sold in packs of ten for $8.60
Old Feb 28, 2009 | 11:25 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Nice finds.
Old Feb 28, 2009 | 12:48 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
87350IROC, God thanks you for finding that! You saved us all alot of time and money. Thanks
EDIT: Are the retaining clips all the same for the A&B-Pillar trim, Door Panels, Headliner, and the clips that hold some of the hatch plastic?
Old Feb 28, 2009 | 08:10 PM
87350IROC's Avatar
Car: 87' IROC
here is what I got for the interior so far
All of this is for a hard top car.
Door Panels
12337920 - christmas tree retainers - maybe 8 per door
A Pillars
20462090 - upper clips - 3 per pillar
363137 - lower christmas tree retainers - 3 per pillar
Rear Interior Plastic
20370594 - plastic nut for large plastic screws - maybe 6 for the whole back interior
Not sure about rear interior christmas trees - anyone know?
Old Mar 1, 2009 | 09:36 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Would someone like to compile a list of all the little pieces for our interior?
If someone can be directed to a diagram of all little tabs, screws, pins that are in/out side of our cars I'll find the part numbers and how many are needed. It'd be a nice sticky for interior replacement. Which I see is hard to find stuff.
Old Mar 1, 2009 | 10:58 PM
yo soy el warg's Avatar
20359997 - Front Headliner Clip. Two required per car.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
