Rust!
Old Apr 6, 2009 | 10:24 PM
SSlegion85's Avatar
Car: 85 Camaro Z28
Engine: TPI 5.0
Rust!
I have an 89 iroc that has rust all over the body. Is that an easy problem to get rid of or should I just strip it for parts?
Old Apr 7, 2009 | 03:46 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: Rust!
It depends on the rust : if it's surface rust it's nothing, just sand to bare metal and prime. If it's rot, then it depends on how much there is and where it is. If it's a rusted out door, replace it. If it's a hole in the quarter panel, weld new material in place of the rot. If it's the frame, she's dead...
Old Apr 7, 2009 | 08:01 PM
Mathius's Avatar
Re: Rust!
Every car is worth saving. Only thing on these cars that is intimidating is rear quarters and the windshield area. Anything else is easily fixed if you have any competent welding skills and actually at least half the car can be replaced with bolt on methods. Unless of course you just got really crazy and started cutting up so much of the body that your whole chassis twists or start fussing with your subframes.
Post pictures, or at least give us a list or we can't help you.
Mathius
Old Apr 7, 2009 | 09:12 PM
SSlegion85's Avatar
Car: 85 Camaro Z28
Engine: TPI 5.0
Re: Rust!
i dont know how to weld but if its sandable i can do it during my free time.
Old Apr 7, 2009 | 09:19 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
Re: Rust!
Looks like you have a lot of work ahead of you. I cant see any rot but its also hard to tell.
Old Apr 7, 2009 | 09:22 PM
SSlegion85's Avatar
Car: 85 Camaro Z28
Engine: TPI 5.0
Re: Rust!
yeah im starting to think if its even worth it or should i just swap the engine to my 2.8? this one is a 5.7
Old Apr 7, 2009 | 09:28 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
Re: Rust!
holy hell...who would do something like that??? check your floors and sub frames before anything...i had a friend that had an iroc and the floors and sub frame were so bad that the axle started twisting...thats when its time to let her go
Old Apr 7, 2009 | 09:32 PM
SSlegion85's Avatar
Car: 85 Camaro Z28
Engine: TPI 5.0
Re: Rust!
my friend has had it sitting there for the 2 years now. he finally decided to sell it so i bought it. the engine is good the the tranny is done
Old Apr 7, 2009 | 09:34 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
Re: Rust!
Old Apr 7, 2009 | 09:35 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
Re: Rust!
thats what he did to it...hes swapping everything out to a solid 86
Old Apr 7, 2009 | 09:57 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Re: Rust!
That's a lot of rust, even though it looks like surface rust, I would hang on and look for a nicer car to start with. 3rd Gens can be found cheap, and most even have paint.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
