T/A fender vents, how are they attached?
Old Apr 8, 2009 | 07:17 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I've been thinking of installing these vents on my Formula. I have some questions, how do they stay on? Is there clips behind the fender, double sided tape, or what?
Old Apr 8, 2009 | 07:44 PM
Mathius's Avatar
Re: T/A fender vents, how are they attached?
IIRC, when Flyinlow92 had his installed, he had them welded in, but that doesn't mean they weren't originally attached by some other means.
If nobody on this board knows, try this site: http://www.transamcountry.com/home/
They have a message board, and they cover 2nd gens.
Mathius
Old Apr 8, 2009 | 08:16 PM
Car: 1994 Trans Am
The vents are metal then, I take it. I had an '88 and an '85 T/A and always assumed they were plastic. I'm thinking of putting them on my 4th gen, but they have poly-plastic fenders. Easier to cut.
Old Apr 8, 2009 | 08:26 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
They are plastic. One end has a couple tabs that slide under the fender and the other end has metal clips that hold it in. The hole in the fenders are recessed a little so the thickness of the vent is smooth with the surface of the fender. For the 85 up, the ground effects also cover the bottom, so the vent hole sits more at the top of the fender hole. The earlier ones had a larger vent hole that was closer to the size of the hole in the fender.
Old Apr 8, 2009 | 08:51 PM
Car: 1994 Trans Am
Thanks man. So the 82-84 vents are bigger? Sweet. I'll look for those then.
Old Apr 8, 2009 | 09:03 PM
Car: 86 T/A
Engine: 5.0 TPI
I don't have an early one to compare but because the 85 gfx came up higher on the fender they kept the same size hole in the fender and made the vent hole smaller and offset to the top.
Old Apr 8, 2009 | 09:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
also, the vents sit into a recessed lip in the fender so that they sit flush, they are not just clipped into a hole. Cutting the hole and adding this lip to an existing set of fenders is practically impossible without warping the panel. Your best bet is to just swap the entire fender. The other option is to cut that section out of the doner fender and try to patch it into yours, which is the end will most likely cost more that just swapping the fenders and re-painting them.
Old Apr 8, 2009 | 09:47 PM
Car: 86 T/A
Engine: 5.0 TPI
I lied I do have an early one to compare. And a pic of the back that shows the tabs and clips.
Old Apr 9, 2009 | 01:30 AM
Car: 1994 Trans Am
Holy ****, I've owned 4 3rd gens and never knew the vents were different. I love learning new firebird stuff.
As for me, I'm still wanting to do this. I bet with some plastic weld and patience I can do it. Cutting is the easy part. I'll have to remove the fenders for sure.
1piece, you don't have any of those 82-84 vents laying around do you?
Old Apr 9, 2009 | 10:10 AM
Car: 86 T/A
Engine: 5.0 TPI
I just have the one early one. I think moulding tape would hold them on just fine and if you smooth out the back they wouldn't stick out much from the fender. It would be pretty easy I think.
Old Apr 14, 2009 | 10:08 PM
83trans's Avatar
do you still have the early set im looking for a set for my 83
Old Apr 15, 2009 | 11:40 PM
Car: 86 T/A
Engine: 5.0 TPI
I just have the one, a left side I think.
Old Apr 16, 2009 | 01:27 PM
83trans's Avatar
what would you want to part with it?
Old Apr 16, 2009 | 10:58 PM
Car: 86 T/A
Engine: 5.0 TPI
$50. There are 2 sets on ebay right now @$125... get em while you can.
morrow
Jan 13, 2024 12:29 PM
F-body-fan
Nov 4, 2015 06:13 AM
my86bird
Oct 23, 2015 12:20 PM
kkirch15
Interior Parts Wanted
Oct 15, 2015 02:21 PM
shanelique22
Sep 24, 2015 06:30 PM
