Rust Bullet???
Old Apr 12, 2009 | 11:09 AM
mongoosekeith's Avatar
Rust Bullet???
has any one used this product? it looks tempting. seems like it would be worth the trial.
http://www.rustbullet.com/
Old Apr 12, 2009 | 11:16 AM
howy03's Avatar
Car: 1985 Pontiac Trans Am
Re: Rust Bullet???
I am using it know and it is great. I use 2 coats let it dry few days go back then topcoat it with primer and paint.did my nose support piece and deck lid under the hood that the hoodlatch attaches 2.
Old Apr 12, 2009 | 02:49 PM
John81's Avatar
Car: 1991 Trans Am
Re: Rust Bullet???
I ordered a 1/4 pint can to fix a couple coin size rust spots on my floorboard. They are not joking when they say not to get it on your skin... took me about a half hour of scrubbing to get it off lol. I'm only using Rustbullet on the floorboards, if/when I do the undercarrige I'll use Rustbullet+Blackshell.
I was originally going to use POR-15 but after reading up on both a bit Rustbullet sounded easier and just as good for what I need it for. It's not cheap but if it does what it's supposed to it's well worth it, only thing worse then fixing rust is having to do it a second time.
Old Apr 12, 2009 | 04:21 PM
Re: Rust Bullet???
i was thinking about trying to do the entire car in it. just so it might last longer. how many sq. ft are our cars so i know how much to buy?
Old Apr 13, 2009 | 01:03 AM
88iroc52387's Avatar
Re: Rust Bullet???
I'll tell ya i've heard alot of good things about rust bullet from a bunch of my friends (they do alot of snowplowing, rust is a common issue with them) As far as rustbullet vs por 15 its a split decision. Half are die hard por 15 while the other half say rust bullet is much easier to apply. The por 15 does have a more truck bedliner finish to it just fyi. I personally ordered a large case of por 15 for the iroc... she'll get the treatment here in a couple weeks as soon as OH weather can make up its mind.
Old Apr 13, 2009 | 01:21 AM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
Re: Rust Bullet???
Am I reading this right? If you have rust spots on your car... You can apply this stuff on the rust spot, and it will stop it from spreading?
Old Apr 13, 2009 | 01:22 AM
Re: Rust Bullet???
thats what i am getting out of it too
Old Apr 14, 2009 | 02:00 PM
confucius101's Avatar
Re: Rust Bullet???
i'm thinking about putting some down on the inside of the car before i start putting her back together then taking her out for a professional undercoating and that way i really should never have anything to worry about when it comes to rust
what do you think
Old Apr 14, 2009 | 02:12 PM
Re: Rust Bullet???
has anyone tried that stuff from home depot that is i think more of a rubber coating from spray can ??????
Old Apr 14, 2009 | 05:29 PM
howy03's Avatar
Re: Rust Bullet???
In my opinion you still need to sand and wire brush.You will never get rid of all the rust it gets in the poors of the metal.But yeah this stuff works great and you can let it cure sand prime and topcoat.It does stick better to a little suface rust but I prefer to get rid of most.I use a combination of bothSEM rust shield witch in my opinion is better than por 15 and rust bullet.I use the Sem on the undercariage and the bullet on body panel spots.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
