Will it work
Old Apr 14, 2009 | 01:04 AM
Camaro87Z's Avatar
Car: 1987 Z28
Engine: 350 L98 interals with Roller Cam
Transmission: T5 Borg Warner non world class
Axle/Gears: 373 posi
Will it work
I was wondering if it is possible to switch over a door with manual components to an automatic components such as the mirror and the window? Reason why i ask is because im paintin my car and i need to get a different drivers door cause mine is to far gone so please need help.
thanks
Old Apr 14, 2009 | 01:40 AM
rangerlaxdude's Avatar
Car: 85 berlinetta
Engine: 350 carb
Transmission: 4 speed auto
Re: Will it work
yea its possible
Old Apr 14, 2009 | 02:19 AM
popballz's Avatar
Car: 89 firebird
Re: Will it work
yes it possible, it all bolts up with different holes, there is holes for both power and manual on every door
i had to do it...BTW, on your new door, make sure there is no bondo on it, i just had to get another door cuz my last one had too much bondo on it.
Old Apr 14, 2009 | 08:19 AM
Camaro87Z's Avatar
Car: 1987 Z28
Re: Will it work
Alright good to know and
Old Apr 14, 2009 | 01:28 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Re: Will it work
speaking of bondo.. (of topic) Would bondo mend well for a small fiberglass patch...
Old Apr 15, 2009 | 06:21 PM
86sdubzzT/A's Avatar
Car: 1986 T/A
Axle/Gears: Stock
Re: Will it work
I am a an old school bodyman and would probably use a fiberglass based filler for that application. I prefer stuff with "strands" in it. Bonds way better (make sure you apply to clean area and push a thin coat on in all the crevaces before building up, air is not your friend) dries harder and resists moisture a heck of alot better than bondo. It is heavier and tougher to work with though.
....First post
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
