Fog light rattle
Old May 3, 2009 | 11:50 PM
tchernobog's Avatar
Car: 1991 Z/28 1LE
Fog light rattle
Alright...I'm sure at least some of you have factory fog lights on your car. I'm even more sure that at least some of those that do have shaky ones.
Is there any 'right' way to fix them, to keep them from shaking so much? I've thought about just kind of...wedging something under/above them...but that's tacky, and half-assed, which isn't how I like to do things. Is there any way to keep the brackets themselves from rattling? Bolts are all tight, but...haha, it's an 18 year old car with a V8 and full exhaust, it has a bit of a physical grumble to it, which translates to the fog lights.
Anyways, I searched for shaky foglights and didn't come up with anything, so if anyone has an trick to keep them from doing it, I'd be much obliged.
Thanks.
Old May 4, 2009 | 02:43 AM
Chilekesh's Avatar
Car: '89 Trans Am GTA
Engine: L98 - 350 TPI
Axle/Gears: 3.27 BW 9 Bolt
Re: Fog light rattle
You know the spring at the bottom of the housing? Add another one there, or just use a stronger spring. That worked well for me.
Old May 4, 2009 | 10:54 PM
tchernobog's Avatar
Car: 1991 Z/28 1LE
Hm...not having one of those would probably explain the shaking haha.
Never knew there was supposed to be one there, thanks for the tip.
Old May 5, 2009 | 07:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by tchernobog
Hm...not having one of those would probably explain the shaking haha. Never knew there was supposed to be one there, thanks for the tip.
IIRC, the spring slides over the adjustment screw.
JamesC
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
andy74
Sep 3, 2015 08:41 AM
