Subframe repair questions..
Old May 10, 2009 | 10:36 PM
nyfireman22's Avatar
Car: 84 Camaro
Engine: 305 V-8
Does anyone know if replacement subframe rails are available? Have rust around the trans crossmember mounting holes on my '84 causing it to twist slightly. Hoping replacement rails are available, if not I guess I'll have to try the fabrication route.. Thanks!
Old May 10, 2009 | 11:11 PM
T_P_S's Avatar
Re: Subframe repair questions..
Well, if you want whole new frame rails and are prepared to weld them on, then a GM parts dealer would be your best bet. Presuming you have a good dealership close to you with parts staff that aren't total jerks, you should be able to go to them and look up which of those rails you would need for your tranny application. They most likely won't be available, but if your parts guys aren't jerks, there is a way they can search the inventories of GM dealerships across the country and maybe, just maybe, they will find what you are looking for that is left over. Either that or they might be available from GM's Vintage Parts place, but since they are body parts they probably will not be available there.
If GM is out, then you are SOL on new ones most likely. You might consider finding a wrecked donor car with good rails if they are that bad.
Old May 11, 2009 | 09:18 AM
madhatter's Avatar
i know that the rears are available, not sure about the fronts. honestly it would be much more of a pain in the *** to replace over fabricating something to correct the problem. and since it is a unibody car, you could replace the front girdle, yet it is not a comonly done procedure, most unibody cars that need that much replacement after an accident are considered totaled. not saying that it isn't done but most of the time it isnt worth it to fix, due to what is involved. best bet is to see if it can be cut out and have a section droped in place, or see if it can be plated. do you have any pics available.
Old May 11, 2009 | 09:41 AM
KnottyBuoyz's Avatar
Car: 87 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Not sure, gotta look it up
Originally Posted by madhatter
i know that the rears are available.
Sorry, don't mean to hijack the thread but do you know where I can get rear sub frames for a third gen?
Old May 11, 2009 | 10:15 AM
madhatter's Avatar
http://www.ecklerscamaro.com/product...dept%5Fid=1427
Old May 11, 2009 | 10:53 AM
Car: 87 IROC-Z
Engine: 5.7 TPI
Thnx Hatter. Lil' pricey. Guess there's not much demand for them yet.
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
tmork454
Sep 29, 2015 06:33 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ironbmt
Sep 27, 2015 06:00 AM
