How to replace clearance light bulb
Old May 12, 2009 | 09:52 AM
Camaro87Z's Avatar
Car: 1987 Z28
Engine: 350 L98 interals with Roller Cam
Transmission: T5 Borg Warner non world class
Axle/Gears: 373 posi
I have an 87Z and I was wondering if anyone knows the best and easiest way to change a clearance light/ turn signal bulb?
thanks
craig
Old May 12, 2009 | 10:04 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: How to replace clearance light bulb
Front marker, side marker or rear tail light? Which is the bulb in?
Front marker go from under the car under the front bumper and twist out and replace then twist back in.
Side marker go in from the engine bay (pass or driver side). On the driver side your horns may be in the way, 2 nuts should remove them and let you get to the marker. Passenger side just move the battery and go in and replace.
For the tail light you have to remove the rear cargo pieces then unbolt the tail lights to remove them, then twist the bulb out and replace IIRC.
All the sizes
http://www.sylvania.com/ConsumerProd...RG-Results.htm
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
