What is the most ghetto thing you've found done to your car?
Old Mar 20, 2010 | 11:25 PM
  #451
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
Re: What is the most ghetto thing you've found done to your car?
PO of my buddie's 85 SC 2.8l removed the AC compressor, smog pump, and EGR INCLUDING THE VALVE ASSEMBLY, and just left the open stand pipe. she also removed EVERY vacuum tube except for the brake booster, so it had close to zero vacuum, also claimed to have the trans rebuilt, but of course 2k later the pump blew apart. I found 35$ in change under my carpet, and a can of chewing tobacco IN my evaporator box.
Old Mar 21, 2010 | 01:31 AM
  #452
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
It amazes me how badly some of these cars have been taken care of over the years.
Old Mar 21, 2010 | 07:53 PM
  #453
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
jb weld for body filler on a replacement hood on my 85 ta. it was straight and mostly rust free. plus only $50 for the whole front clip.
a 2x4 holding up the gas tank on a dodge k-car.
a 5 inch hose clamp for a cv boot clamp on the k-car.
rtv around the entire trans and oil pans on the k-car.
bungee cord holding down the battery on a 83 dodge truck.
about 10 feet of 3/8ths inch fuel line from tank to fuel pump on the same 83 dodge truck.
toggle switch for a headlight switch on the 83 dodge truck.
a piece of sheet metal in place of a rust hole the size of a man hole cover on the 83 dodge truck.
expandofoam attempting to seal everything on the cab of the 83 dodge truck.
hose clamps for exhaust hangers on a 77 olds holiday 88.
Old Mar 22, 2010 | 12:32 AM
  #454
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Chewing tobacco, very nice. Getting my tranny put in Brandon. I cant wait. Should be ready by Tuesday. Once I get her back, Im gonna take her out for a test drive .
Old Mar 29, 2010 | 10:32 AM
  #455
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
When I first got my car the driver side of the frame where the trans crossmember bolts to was being held in by drywall screws. Yeah the prior owner said he replaced the floors with all new metal. LOL what a crock thank god I can weld
Old Mar 29, 2010 | 11:13 AM
  #456
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
What's with third gen people and drywall screws?!?!
Old Mar 29, 2010 | 11:32 AM
  #457
jj74sd455's Avatar
Car: 91 bird
Engine: 305 tbi
Transmission: 4 speed automatic
Axle/Gears: factory
someone had replaced my catalytic converter with a muffler on my 89 ta,had a 77 ta someone had pop-rivited a patch panel and bondoed over the whole rusty thing,my 84 blazer k5 has some rust holes someone just filled in with that expanding foam sealer,my 71 gmc 396 had a chain holding the hood down.good stuff
Old Mar 29, 2010 | 11:35 AM
  #458
87WS6's Avatar
I don't know but a friend of mine found some in his car and I've found them in one of mine.
Makes you go WTF?
Old Mar 29, 2010 | 12:57 PM
  #459
6SIX6's Avatar
Car: 89 IROC
Makes you go WTF?
I also had them holding down in place my sill panels and my kick panels as well. I guess it was an ongoing theme
Old Mar 29, 2010 | 01:12 PM
  #460
87WS6's Avatar
Mostly I found sheet metal screws in odd places in my car. There were a few wood screws here and there which I mentioned earlier. I also had unusually long screws holding the speakers in place. They were over 4 inches long. They looked long enough to go through the side of the car.
Old Mar 29, 2010 | 02:23 PM
  #461
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Previous owner drilled through the back hatch area into the gas tank.
Still can't figure out what for. But I had to plug the holes in the gas tank.
Old Mar 29, 2010 | 02:26 PM
  #462
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Breather hole...haha. Some people...
Old Apr 2, 2010 | 12:53 AM
  #463
np camaro ak's Avatar
Car: 86 camaro
Engine: carbureted 305
Transmission: stock auto
Axle/Gears: stock
so did i and 2 cigarette lighters for the carsciglighter and a ton of ashes some gum and an old movieticket
Old Apr 2, 2010 | 10:16 AM
  #464
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
What was the movie
Old Apr 6, 2010 | 11:03 PM
  #465
Guess what I did. I cut off one of the metal pipes that come off of the heater core and installed it in place of the pipe that curves out infront of the throttlebody. I did this to re-route the coolant for the coolant by-pass/throttlebody mod. Looks ok though. It hugs the altenator braket and the way the tube is curved, it looks clean. I'll take a picture tomorrow to show what Im talking about.
Old Apr 7, 2010 | 11:05 PM
  #466
dvdlovesbball's Avatar
Car: 1987 iroc-z
Engine: 5.0 305 carb
Axle/Gears: stock 10 bolt
my battery cables were conectted to the terminial with self tapping wood screws, pinched off rear brake line because the guy was to lazy to fix it ( still have to get around to doing lol), and my dash cover was held on with double sided tape
Old Apr 8, 2010 | 01:26 AM
  #467
87WS6's Avatar
Nice.
Old Apr 10, 2010 | 07:03 AM
  #468
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
prolly for an external amplifier.
Old Apr 10, 2010 | 07:31 AM
  #469
MrPhotographer0's Avatar
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
Having pulled out the carpet, i think i've found all the interior secrets. i've found enough change to pay back half of the car, screws for everything and more, drywall screws, self tapping screws, 2 movie tickets, condom wrapper, toilet paper tubes, a 6"orbital buffer, the power seat run to wires in the fuse box, ground wires from the park neutral saftey switch run to the tranny pan and thats about it so far. oh, and a 04+ grand prix spoiler on the back.
Old Apr 11, 2010 | 02:24 AM
  #470
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
po also drilled a hole through the gas cap. every time i filled up i lost half my gas over the side of my car
Old Apr 11, 2010 | 03:35 AM
  #471
The_rabbit1's Avatar
Car: '87 Iroc
Engine: 350 .060 over
Axle/Gears: 3.70 9bolt
Victor junior heads, ported and polished, with a itty bitty cam. Starter with no shims, Cam with mismatched (dual) valve springs, non hardened (stock)pushrods with guideplates with said springs, roller tip rockers that didn't clear the wide as hell mismatched springs, stock ecu on top of all that.
Old Apr 11, 2010 | 10:57 PM
  #472
Okay guys. I got my pictures now. Im gonna paint the tubes but it'll do for now. Oh, I also need to grind down the extra piece of tubing that is soldered/welded too.
Attached Thumbnails What is the most ghetto thing you've found done to your car?-heater-core-tube-1.jpg   What is the most ghetto thing you've found done to your car?-heater-core-tube-2.jpg
Old Apr 12, 2010 | 08:53 AM
  #473
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I don't understand this one at all. can you explain it more?
Old Apr 15, 2010 | 03:06 PM
  #474
CodyC123's Avatar
Car: 86 Z28
Engine: 385
Transmission: T5 (soon to be in pieces)
Axle/Gears: 3.73 POSI Disc
Well my i tore my engine dow to find out it had 7 matching pistons with one oddball and three different types of rod bearings
Old Apr 15, 2010 | 10:12 PM
  #475
v8_musclehead's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: 5.7 L, 350 TBI
Transmission: Borg-Warner T-5
When I bought my '91 RS, there was no head unit installed. The PO gave threw in his aftermarket so I had something. I later re-rewired my speakers due to no sound coming from the rear. The head unit harness was hacked up and the rear speakers were connected with clear home theater speaker wire. The front left speakers positive terminal connection was made up of the wire being stripped bare and looped around the terminal instead of stamping a connector on the wire.
Old Apr 15, 2010 | 10:14 PM
  #476
??? Makes no sense... Why wouldn't you just buy a new cap? Or is this just your attempt at being humorous? :P
Old Apr 15, 2010 | 10:20 PM
  #477
87WS6's Avatar
Holy crap. That's not the type of thing you want to find when tearing down an engine. Though I guess it beats huge cracks and other problems. Still you've got to wonder what the hell the builder was thinking.
Old Apr 19, 2010 | 08:46 PM
  #478
Jaseman32's Avatar
Car: 89 RS Gunmetal Gray
Engine: 350 TBI
Originally Posted by 88TransAmFreak
I'm curious, as our cars are getting older and people just don't want to invest the money into "fixing it right"
What are some of the goofy things you've found done that the PO ought to be hung for?
My firebird was in pretty good shape when I bought it, but my Corvette had the throttle cable assembly rigged up with speaker wire and the engine shimmed with huge washers (bad frame) when I bought it
I've heard stories of owners pulling carpet and finding a floor patch made of an old metal sign or even wood.
Anyone want to share their experiences
Two different sets of wire nuts within 6 inches of each other for the rear speakers. Lame!
Old Apr 20, 2010 | 08:30 PM
  #479
knobs's Avatar
Car: 1989 IROC-Z L98
Engine: TPI 5.7
Axle/Gears: 2.77
When I got my IROC I noticed that the emergency brakes barely had any pull at all. Lo and behold when I got it up, the emergency brake cables were actually green weedwhacker line that was attached to the calipers and front cable bracket by knots.
Oh and the PO just couldn't be more proud of how the A/C blows cold in the summer on a 100 degree day. And it did blow cold, until it all leaked out. I don't feel bad though, since by the smell I realized it my A/C was filled with propane.
Old Apr 20, 2010 | 08:48 PM
  #480
87WS6's Avatar
WTF?
Old Apr 20, 2010 | 08:56 PM
  #481
porpane is good to use in Rvs cheap for a/c. But imagine if it blew up. whats the ratio again 98%air 2%propane for combustion?
  #482
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
I found an electric fan wired up without a relay. It was wired to a switch on the dash. luckily one of the wires was pulled off the switch.
Old Apr 20, 2010 | 09:01 PM
  #483
Chevy8588's Avatar
R-134A is just as explosive, propane will actualy yield colder temps
Old Apr 20, 2010 | 09:29 PM
  #484
87WS6's Avatar
That's one of the many things I found wrong with my 1985 Trans Am. A secondary fan was added as was a transmission oil cooler. The latter was installed with zip ties and the former was bolted in with a piece of metal which was obviously a bracket for something else. It was screwed into the radiator support and the tray in front of it with various sizes of sheet metal screws.
Old Apr 20, 2010 | 10:24 PM
  #485
WHTrunner's Avatar
Car: 1986 Z28
I just got this camaro last week.
First thing that stood out when I looked at it was the shifter. I don't know what the hell it is, but it looks like it should be in an airplane. The guy cut the hole for the original shifter bigger to make it fit. I can't tell if I'm in neutral or drive. I just have to hit the gas and see.
My neighbor called the sheriff on me the other day because of me revving the engine in my driveway.
Part of the old shifter is still laying in there. You can see it through the massive hole in the console.
The MSD is bolted to the floor on the passenger side. It has wires hanging off of it, and it looks like it's older than the car.
And here's one that's bugging me right now. One of the louvers is glued on to the hood with liquid nails. The front two-thirds of it is busted off, but the rest of it isn't going anywhere. I just hope the other one isn't in the same condition.
Old Apr 20, 2010 | 11:07 PM
  #486
87WS6's Avatar
I wouldn't have purchased a car like that. Though I do totally understand getting surprised by some of the things you find after the sale. I found tons of hidden rust under my 1987 Trans Am.
Old Apr 20, 2010 | 11:16 PM
  #487
RUST! Did you remove and replace the floor pans? Or did you do a ghetto job too? I will confess. Due to my wages, I had to do some ghetto stuff to get me by too. I think we all have done something ghetto to our thirdgens. But who's willing to admit it I just admitted. Anyone else?
Old Apr 20, 2010 | 11:18 PM
  #488
Chevy8588's Avatar
I ripped my v6 out... and replaced all the po's hacked wiring with a complete properly modified dual fan TPI harness.. then a freshly properly rebuilt TPI v8....and a freshly properly rebuilt 700R4.... .. nope nothing ghetto here at all! at least not for my third gen... my DD caddy OTOH... XD
Old Apr 20, 2010 | 11:35 PM
  #489
Whats up my friend. How she runnin (85 Camaro)?
Old Apr 20, 2010 | 11:37 PM
  #490
Brandon, I'll get at you tommorrow about my Reman tranny. My wife just kicked me off my computer. She is . But I luv the woman.
Old Apr 20, 2010 | 11:39 PM
  #491
87WS6's Avatar
No, the rust isn't that bad. I'm doing NOTHING ghetto about it. I'm cutting out the old metal and I'll be welding in new metal from a donor car. Actually most of it is in the wheel wells and not so much the floor pan. there is some at the firewall in front of the driver's side sub-frame. The stuff that is in the floor pans is actually fairly small and I can patch that stuff with donor sheet metal from my parts car as well. At least most of it. I'll be grinding down the welds and painting on both sides of the rust or undercoating over it with rust bullet. If I do a good enough job, it should be hard to tell that anything was ever done to it. Everything down to the stereo wiring was done right with this car by the previous owner. I'm not about to make a mess of it now.
I've never had to do anything ghetto to my thirdgens because none of them have ever been my daily drivers.
Old Apr 21, 2010 | 01:36 PM
  #492
Old Apr 21, 2010 | 02:04 PM
  #493
87WS6's Avatar
Its funny, after we had our conversation I had to do something ghetto to my car. I removed the air cleaner to work on the carb which has loose butterflies and a sticking throttle. When I pulled the air cleaner off, the hose going to it from the valve cover snapped off. So now I've got it repaired with a hose clamp and some duct tape.
Its temporary I assure you.
Old Apr 21, 2010 | 06:30 PM
  #494
O man that just goes to show even if your trying to be a purest, you'll sooner or later do what we all try to avoid. At least you have the temporary repair material at hand.
Old Apr 21, 2010 | 06:55 PM
  #495
87WS6's Avatar
I plan to ditch that junk Edelbrock carb for a Demon or a Holley. I'll get it straightened out then.
Old Apr 23, 2010 | 12:52 AM
  #496
Well, I didnt find anything other than this ghetto Camaro out on the web,
I posted these pictures on an other thread but I felt that this Camaro needed a spot here in the "Ghetto" thread.
Old Apr 23, 2010 | 08:02 AM
  #497
Jaseman32's Avatar
Engine: 350 TBI
I think you win.
Old Apr 23, 2010 | 08:25 AM
  #498
Zyddian's Avatar
Car: 84 Firebird
Engine: V8 383
Transmission: 700 R4
Oh man as far as doing ghetto things go I have done my fair share... I try now to avoid all of this though at all costs. I am older and wiser now...
I have repaired exhaust with coat hangers, and or bailing wire. Made cotter pins out of coat hanger. Sadly this actually works pretty good. Used duct tape on almost anything and everything. Used household speaker wire for car audio ((( But really what youngster hasn't?))) I have patched holes with liquid metal, and or jb weld.. Used electric tape instead of connectors like you always should! I could be here forever listing these but I'll keep it short.
Zyd
Old Apr 23, 2010 | 07:56 PM
  #499
WHTrunner's Avatar
Car: 1986 Z28
That looks less like a Camaro, and more like a fish.
Old Apr 23, 2010 | 10:11 PM
  #500
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
I just vomited in my mouth after seeing that piece of schart.....
