door bouncing in jam after new pins
Old May 28, 2009 | 10:09 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I installed Lons hinge pin kit in my passenger door. and a new striker. my door still seems to bounce in the jam when I hit big bumps.
Anyone have any ideas?
Thanks,
Kory
Old Jun 24, 2014 | 06:50 PM
raiderkush's Avatar
Car: 91 & 90 Camaro RS
Engine: 305 TBI
Transmission: Manual T-5
Re: door bouncing in jam after new pins
Did you ever solve this problem?
Old Jun 25, 2014 | 10:53 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
The "jaws" that close around the bolt need to hold the bolt tightly to prevent up/down movement. You could replace both or try putting some thin plastic pipe on the bolt to compensate for wear. I "solved" the problem by screwing a wooden shim to the sill plate that the door sits on. Quickest/cheapest.
Old Jun 25, 2014 | 06:59 PM
raiderkush's Avatar
Engine: 305 TBI
Looking at my jaws & I see the hard plastic coating is wearing away, and a shim sure does sound easy, thanks for reply!
gta892000
Aug 11, 2019 11:16 AM
Veaceonee
Sep 29, 2016 08:15 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
