Ideas on Paint Materials Needed?
Old Jun 17, 2009 | 10:00 PM
White89Firebird's Avatar
Car: 1989 Pontiac Firebird
Engine: 2.8L V6
Transmission: ?
Axle/Gears: ?
im looking to paint my89 pontiac firebird and i want to paint it white but i dont know the stuff to do it with.
any ideas on:
paint guns
acrylics
and other materials needed
btw im new at this so please dont judge me.
im just a guy trying to learn.
Old Jun 18, 2009 | 08:54 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
Re: Ideas on Paint Materials Needed?
ok so white paint is one of the easiest to paint, and for body work white is very forgiving vs black.
here is the thread from years ago when i did my camaro much more custom than white but the steps are all there.
what color is the car now? if its a color change you have to pull the doors hood hatch ect and jamb the car out in the new color the put all the parts back and paint the rest to get the best job.
you need a good big compressor like 10 cfm big, paint guns take alot of air and d/a takes even more air.
as for a gun devibiss finish line is a good starter gun with a 1.2 tip you can do base and clear with the same gun.
read this thread and post up any questions
https://www.thirdgen.org/forums/body...d-threads.html
Old Jun 18, 2009 | 10:40 PM
Engine: 2.8L V6
Transmission: ?
Axle/Gears: ?
Thanks man I really appreciate the info. Btw you think September would be the best time to paint a car? If not, when is the best time
Old Jun 19, 2009 | 09:49 PM
JeffW's Avatar
Engine: 305 tpi LB9
depends on where your doing the work? if you have a booth or not, how humid is it, temp is not that big an issue, humidity is the one to watch, the dryer the better.
Old Jun 20, 2009 | 08:49 PM
NatesZ/28's Avatar
Car: '00 Regal GS/'87 T.A WS-6
Engine: stock 3800 series II/stock 5L TPI
Transmission: fwd auto/stock 700r4
Axle/Gears: wrong wheel drive/3.23:1 Posi
Paint? Napa base/clear. Acrylic? AVOID 'single stage Urethane' this is base and clear in 1 can. You absolutely can NOT fix screw-ups with this so AVOID IT.
Urethane OEM paint? Napa or if you want to go Acrylic Enamel Id still suggest napa, unless you want like 40 dollar a gallon Industrial Acrylic Enamel.
Gun? Bar non for a budget? the Astro brand guns are way better quality than any of the other knocksoffs. For a Primer gun? pick up the HVLP gun from Harbor Freight/Princess Auto when its on sale for 12 Bucks.
Youre also going to need a selection of Duroblok sanding blocks, a couple packages of sandpaper (80grit, 120grit (wet/dry) 220wetdry, 400wetdry, 600wetdry, 800wetdry and 1000grit wetdry. Id also get some 1500 wetdry before you buff it. Also get a can of Bondo Professional bodyplastic.
Use a good epoxy sealer under your basecoat. After you buff the paint, let it sit a week before you wax it to let all the solvents gas out
Old Jun 20, 2009 | 09:05 PM
Irocz28NCHS's Avatar
Car: 1986 Irocz28
Engine: 305 tpi
Axle/Gears: stock
accept one thing if you have a good budget for paint it isnt too expensive but using PPG paint can be another choice that would work and it turns out great. has a good shine. and if you go to NAPA they have a really nice gun for about 120 and just use the harbor freight gun for primer. ill get the brand of that gun from napa for you if you would like.
Old Jun 20, 2009 | 09:06 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
noob painter without the equipment, you might want to try the roller method detailed here:
http://board.moparts.org/ubbthreads/...0&fpart=1&vc=1
actually gets nice results, about halfway through the first page the guy's got a couple photos of his charger.
IROCZ1989
Jan 24, 2016 03:55 PM
Golfvette
Aug 24, 2015 06:35 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
