window sweeps problem
Old Jun 20, 2009 | 10:36 PM
edeyethejedi's Avatar
Car: 1989 RS Camaro
I just replaced the window sweeps on the driver side of 89 camaro. After everything was put back together and the window was rolled back up I noticed that it does not seal evenly and there are gaps that will let water go down into the door. Sweeps were purchaced from Classic Industries, the pack said the restorers choice part #2064. Does anyone have a fix for this.
Old Jun 21, 2009 | 09:59 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: window sweeps problem
Have you put the interior trim panel back on yet? That may press the glass out a little more. Is the window adjusted properly? I don't know if there is a fix for your problem, but perhaps it's not as big a problem as you think. Doors have drains in the bottom to let any water out that gets in.
Old Jun 22, 2009 | 07:25 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
As said above you will have to re-adjust the window I took a water hoes to mine.I seen the leak then re-adjusted ,water..... finally I got it to seal againit will take a little time to get it back to perfect.
Old May 31, 2011 | 12:49 PM
tom camaro's Avatar
Car: 83 Camaro
Engine: LT1 SD Mode 30lb/hr
I too bought the Classic Industries window sweeps and am seeing the same problem.
For the life of me I cannot get them to seal against the window.
Old May 31, 2011 | 04:58 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I used OEM with no problems. Glad I did now.
Old May 31, 2011 | 05:15 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
We have new original GM sweeps available on our site. The quality of them is FAR superior to the aftermarket pieces available. Unfortunately, aftermarket pieces rarely fit as well as originals.
Old May 31, 2011 | 09:48 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if the window's been adjusted and you're still having issues, check the bolt spacing on the door. i have seen some cases where they are not uniform to mount the outer seal (think friday at 4:59pm at the assembly plant - gotta hurry it up so i can go home!). when this happens, the bolts can pull the sweep a little bit and bunch it up. if that is the case, just enlarge the holes a little and it should fit more flat
Old Jun 1, 2011 | 07:35 AM
tom camaro's Avatar
Car: 83 Camaro
Seeing how I have revived a three year old thread. I'm going to start a new one to see if anyone else has had the same problem with the Classic Industries seals.
For 1ADan: The seal is not bunched. I acctually had to drill 2 holes in the seal to align two of the mounting bolts. It is laying flat and looks good untill you shut the door and then you see the gap. Its like I have to choose the leak to be at the cab and window or a the window sweep and window. If I push the window out far enough to close the window sweep gap it no longer seals tight at the top of the car.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
evan555222
Sep 20, 2016 02:51 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
