Need Help with Bumper Problem
Old Jun 21, 2009 | 05:02 PM
CamaroTD's Avatar
Car: '86 camaro Z28
Engine: 383 Carb
I had the old quarter panels cut out and new ones welded in on the car. The problem is that the passenger side is now out slighty farther and therefore, i cant get the rear bumper to sit tightly against the body. I have a small gap between the bumper and body and the same slightly smaller between the bumper and quarter Fx. Is ther anything i can do such as shave a little off the rear impact bar and see if that helps? Thanks
Old Jun 21, 2009 | 09:34 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: Need Help with Bumper Problem
When the cover is bolted up is it really that tight to the impact absorber? Sanding some of the plastic down shouldn't be a problem but there may be a better solution. Do you have a pic?
chazman
Aug 28, 2018 03:25 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
greenyone
Sep 2, 2015 03:39 PM
mikey8494
Aug 22, 2015 07:57 PM
chazman
Aug 22, 2015 02:01 PM
