fixing spiderwebing
Old Jun 21, 2009 | 05:22 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
fixing spiderwebing
hi guys, just wondering what would be involved in fixing this?
would i just sand it down to the bare plastic,would i need to use filler?
any help would be appreciated.
thnks Sid.
Old Jun 21, 2009 | 05:50 PM
NT-Z's Avatar
Car: Had 2 iroc-z's . An '87 & '88.
Engine: HAD 5.0 & 5.7 tpi
Axle/Gears: stock
Re: fixing spiderwebing
Ooh, thats a tricky 1. That happened to my previous camaro. They way I would do it is sand it down completley, prime it and sand it. Then apply a skim coat o filler. Then sand and prime, sand and prime etc... The nose flex so that might be a reson why its webbing. Other people might have another method.
good luck
Old Jun 21, 2009 | 06:01 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i'm by no means a paint/body man . it looks like just the clear coat to me . a decent paint man should be able to take care of it . i understand there is a flex agent that should be used on plastic . good luck .
Old Jun 21, 2009 | 09:14 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Most of the time when we see that type of damage the paint is fractured but the plastic is fine. But it is cracked for a reason, either an impact or someones fat a** sitting on it, or possibly a poor quality previous repair. All you probably need to do is sand it down and refinish it, but you should play close attention as you sand for areas that are into the plastic.
Old Jun 21, 2009 | 10:05 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Yeah, as long as you sand that down to the plastic you should be fine.
Old Jun 22, 2009 | 01:55 PM
sid rs91's Avatar
Transmission: wc T5
whats the best grit paper to use? what sort of sander?
the damage was from the 1st owner bumping in to stuff,....the plastic it self is fine have checked from underside and rubbed down section over one of the "cracks", it's smooth under the paint.
Old Jun 22, 2009 | 11:40 PM
Car: 86 T/A
Engine: 5.0 TPI
If you're going to take it off the car and since it looks like the problem is pretty wide spread, I'd look for a bumper reconditioning company in your area. They'll strip it, do any necessary repairs and prime it. When you get it back it will look like new.
If you want to do it yourself or if you're not taking it off the car, I'd start with some 120 grit on a DA or random orbital sander to take most of the paint off and then hit it with some 180 to take it down the rest of the way before you prime. If you prime over too course of sand scratches on plastic it tends to look fuzzy and takes a lot of extra primer to fill the textured surface.
Old Jun 23, 2009 | 09:14 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
To answer your original question repaint is what is needed. You need to have Flex additive in your paint to prevent that. A real body shop will use that when they re paint the bumper.
Old Jun 23, 2009 | 02:05 PM
sid rs91's Avatar
Transmission: wc T5
Thanks for the tips guys....didn't think of taking to a reconditioning place, will have to look in to that.
Bubbajones_ya
Oct 25, 2015 08:01 PM
Reid Fleming
Oct 10, 2015 09:56 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
