Hood, weird?
Old Jun 28, 2009 | 07:47 PM
Nick White's Avatar
Car: 89 Firebird
Engine: 2.8L
Transmission: TH700r4
Axle/Gears: 3.43
Hood, weird?
Hinges:
BTW it's not a stock hood, i think it's 86? 84? Trans am, on my 89 base.
HELP HELP HELP. how do i fix this?!
Ok i will post two posts, cause i can only do 5pics at a time.
Nick White's Avatar
Car: 89 Firebird
Engine: 2.8L
Axle/Gears: 3.43
Re: Hood, weird?
Old Jun 28, 2009 | 08:00 PM
ttoplover's Avatar
Car: 1989 Trans Am
Engine: 305 tpi
Re: Hood, weird?
Originally Posted by Nick White
that is the bulge hood that was on 82-84 trans ams and 85-90 formulas
Old Jun 28, 2009 | 08:20 PM
Nick White's Avatar
Car: 89 Firebird
Engine: 2.8L
Axle/Gears: 3.43
Re: Hood, weird?
Ok, but how do i fix it?
Old Jun 28, 2009 | 08:42 PM
ttoplover's Avatar
Car: 1989 Trans Am
Engine: 305 tpi
Re: Hood, weird?
is there anymore adjustment at the mounting bolts?
Old Jun 28, 2009 | 09:04 PM
Nick White's Avatar
Car: 89 Firebird
Engine: 2.8L
Axle/Gears: 3.43
Re: Hood, weird?
What do you mean?
Front, back?
Old Jun 28, 2009 | 09:12 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: Hood, weird?
My hood does that too, not as bad as that though. And if I push it down it'll lok normal and stay that way.
Old Jun 28, 2009 | 09:15 PM
Nick White's Avatar
Car: 89 Firebird
Engine: 2.8L
Axle/Gears: 3.43
Re: Hood, weird?
When i push it down it comes right back up. sucks.
Old Jun 28, 2009 | 09:21 PM
Stephen's Avatar
Car: 87 GTA
Re: Hood, weird?
Right behind where the hinges mount on the body, there are the screw up/down cushions, that could be holding the hood up.
Or....
Is the hood fiberglass? If so, the struts for steel hoods are typically too strong & will push a hood up like that.
OR.....
Again if it is fiberglass, the vertical edges could be too tall & need trimming, to allow it to sit lower.
Of the 3, my $ is on the first possible cause I mentioned.
Old Jun 28, 2009 | 09:23 PM
Stephen's Avatar
Car: 87 GTA
Re: Hood, weird?
If yours stays down after pushing on it, my $ is on the struts.
Old Jun 28, 2009 | 09:24 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Hood, weird?
first take all the mounting brackets off and see if it fits without the hardware. if it does then its just a matter of moving brackets. if it doesn't then you are in bad shape and may have to change the hood sheet metal.
Old Jun 28, 2009 | 09:46 PM
Nick White's Avatar
Car: 89 Firebird
Engine: 2.8L
Axle/Gears: 3.43
Re: Hood, weird?
Before:
After:
Before:
After:
Thanks Stephen! That was the problem.
Thank you everyone else for the help anyway!
Old Jun 28, 2009 | 11:29 PM
Car: 1990
Axle/Gears: stock
Re: Hood, weird?
it still does not look like it fits even.
better but not even. is it the angle of the pic?
Old Jun 28, 2009 | 11:49 PM
Nick White's Avatar
Car: 89 Firebird
Engine: 2.8L
Axle/Gears: 3.43
Re: Hood, weird?
Nah, it's just better. It's not 100%, but the bolts all the way down, is there anything else i can do to bring it down?
Old Jun 28, 2009 | 11:51 PM
Stephen's Avatar
Car: 87 GTA
Re: Hood, weird?
Still up a bit, huh?
Take the adjusters all the way out. Maybe they are simply too thick for that hood? If so, you can live without them, or try to find thinner ones.
Old Jun 29, 2009 | 12:34 AM
Nick White's Avatar
Car: 89 Firebird
Engine: 2.8L
Axle/Gears: 3.43
Re: Hood, weird?
I'll try that when I get home.
It's not fiberglass, I wish it was.
If it still doesn't go all the way down, is there another way to lower it?
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
