Hatchback Trunk Problem
Old Jul 9, 2009 | 11:32 AM
YoungMoneyVII's Avatar
Car: 1990 Pontiac Firebird T-Tops
Engine: V8 350 5.7 L TPI
Transmission: Overdrive 700R4 (Auto)
Axle/Gears: 9 Bolt/GU5AXLE,REAR3.23 RATIO3.23R
My birds hatchback does not close fully sometimes but will stay shut. It doesnt leak to my knowledge and sometimes it will go down fully and stay down but if i open it after it had been staying down it doesnt go back into the down position. When i bought it the previous owner removed the Fuse 20 for the Trunk im not sure if that fuse is even in now but there is a new case of them in the center console. Any thoughts? I think it might be the trunk motor thing.
Old Jul 10, 2009 | 01:07 PM
1Aauto's Avatar
Former Sponsor
Re: Hatchback Trunk Problem
If it's not pulling down all the way,or only pulls down part way and keeps turning the plastic gear in the motor in more than likely stripped.
We carry new hatch pull down motors if you need a new one.Here's a link to them on our site.
Pontiac Hatch Pull Down
Old Jul 10, 2009 | 02:05 PM
thanks Tony, im pretty sure its the first one you desribed, since I believe Fuse 20 is not in the motor will not turn the plastic gear. The previous owner said when the Fuse is in the motor just keeps sucking the trunk down and it doesnt close.
Old Jul 10, 2009 | 02:22 PM
1Aauto's Avatar
Former Sponsor
No problem,anytime.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
