Did base model Camaro come with different colored gfx?
Old Aug 7, 2009 | 06:24 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I was looking at a Camaro forsale that had different colored gfx. It must have been pre 86 (no third brake light), It was red with gray gfx. I was under the impression that only z28's had different gfx. I wanna be informed before I contact owner. Any info would be very much appreciated.
Old Aug 7, 2009 | 10:07 PM
Stratocaster25's Avatar
Car: 1992 Z28
Engine: LB9 305
Re: Did base model Camaro come with different colored gfx?
I think the first base model to get ground effects was the 1988 SC camaros that had the "Camaro" on the door ground effects. Those had different color ground effects, but they would also have a third brake light. Maybe it was a pre '86 SC that somebody put ground effects on themselves.
Old Aug 7, 2009 | 10:15 PM
That's probably the case. the gfx say "Camaro" on the sides, and on the back. Could be an add on, or maybe the back window could have been replaced with an older one. Thanks for the info. I'll take a better look at it with the owner there so I can pick..
Old Aug 8, 2009 | 02:09 AM
Car: 1992 Z28
Engine: LB9 305
Also what kind of spoiler did it have? Those '88 Sport Coupes had a different type of spoiler than any other Camaro. It almost looks like a '91-'92 Z28 spoiler except it isn't as tall. If it has that spoiler then most likely it's a 1988 with a different back window. If it doesn't then it's probably an older SC with ground effects added to it.
Old Aug 8, 2009 | 09:24 AM
89junkyardgta's Avatar
Car: 1989 GTA, 1985 T/A
Engine: L98, LG4
Transmission: Slush-o-matic 700R
Axle/Gears: stock and stock
Yup, something sounds amiss, however, these cars have been around so long, lots are modified in some regard. Look for accident damage!!!! I have been through nearly a dozen thirdgens between myself and my brother, and whatever isn't rotten has been hit.
Old Aug 8, 2009 | 09:45 AM
The spoiler looks the same as my iroc, and rs. I believe it an older base camaro, w/gfx's added on.
Frozer!!!
Jan 19, 2024 04:55 PM
Grant2k
Jul 10, 2018 04:01 PM
Linson
Aug 21, 2015 02:12 PM
Fronzizzle
Aug 9, 2015 01:15 PM
87350gtanj
Aug 8, 2015 10:32 AM
