removing gfx piece behind rear wheel
Old Aug 11, 2009 | 08:15 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I need to remove the gfx on my 86 IROC, the piece behind the passenger rear wheel. I took the two screw out underneath, holding the piece up, but there is something holding it that I cannot see. Any input would be appreciated.
Old Aug 13, 2009 | 01:29 AM
popballz's Avatar
Car: 89 firebird
Re: removing gfx piece behind rear wheel
on my '89 firebird, there is 3 bolts on the inside, two screws by the wheel and 3 screws on the bottom.
for the ones on the inside, you gotta take the rear side panel out on the inside of the car.
Old Aug 13, 2009 | 09:31 AM
my82roc's Avatar
Car: 89 Iroc Convertible
There are 2 studs that go thru the body and attach with 11mm nuts.You will need to get behind the interior hatch panels to access them
Old Aug 13, 2009 | 04:54 PM
I think it's behind the spare tire. I'll try to look at it tonight. I needed to do a minor touch up and the gfx needs to be removed to do it properly. Thanks for the info. I'll keep ya posted.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
