86 with 92 headlights?
Old Aug 14, 2009 | 11:34 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
don't ask how or why too much to explain
but i noticed my 1986 headlight wiring has 3 wires
92 headlight has 4 wires but 2 are the same color and in the same socket/connection
so is it a straight forward splice in?
anyone have any info on this upgrade/conversion?
Old Aug 15, 2009 | 12:51 AM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
Transmission: stock BW 5 spd.
Axle/Gears: stock 3.42
Re: 86 with 92 headlights?
are you trying to put the smaller 92 headlights in your 86 or are you asking if the motors are interchangable
i don't know about the interchange part but I have a good suggestion for the other thing... swap your 86 motors onto the 92 headlight assemblies, or just swap the part the headlight is bolted to, the part that flips up, I forget how but they do come apart pretty easily....
hope this helps/
Old Aug 15, 2009 | 01:14 AM
Bobby_80s's Avatar
Axle/Gears: no idea
teh mechanics of bolting i will figure out or fabricate
im talkin about wiring the 91-92 headlights in a 86 harness/plug
Old Aug 15, 2009 | 05:40 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
*edit* never mind, I answered for something completely different.
Old Aug 15, 2009 | 05:46 PM
Bobby_80s's Avatar
Axle/Gears: no idea
so just wiring in the headlights directly isn;t gona cut it electronically?
i get that the 87 + years use a different system but im just wondering why does my car care or know there is a different headlight pluged in?
not thinking about motors im saying just specifically the headlights
i guess what im asking, can i get the 91-92 headlights and headlights only to work with my 86 wiring?
i mean in basic terms a headlight is a headlight. and there are 3 colors in my 86 headlight. tan green and black
same with these 91-92 headlights i have with the plug/wiring. tan green and black
i'm gona try it out, if i run into problems o well.
thanks for the info deadbird
Old Aug 15, 2009 | 05:56 PM
deadbird's Avatar
Engine: TPI 305/ v6
Sorry about that, for some reason I got headlight motors stuck in my head.
The wiring should just splice color for color. The glass housed lamps (sealed beam) have to have a ground wire as the glass insulates them from a chassis ground.
I've never really had the opportunity to see the 91-92 lamp wiring up close and I don't remember what lamp they take but, as a guess, they may have some way of getting chassis ground just by being bolted in. That would eliminate the 3rd (black/ground) wire.
Old Aug 15, 2009 | 06:06 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok thanks,
no worries,
i did a knight rider kitt, and the bigger headlights on my 86 are showing through the turn signal blackouts and is illuminating all the hardware keeping the blackouts from flying offf.
looks like crap at night. or with the headlights up i should say.
closed looks mint.
so i wana try putting the smaller headlights/trim(i'lll make it fit) and the beam of the headlights will be above the turn signals
thats the plan. treating my blackouts like its a 91-92 bumper the headlights are above that line.
Old Aug 15, 2009 | 06:48 PM
Stephen's Avatar
Car: 87 GTA
I'm trying to figure WHY you wanna out the smaller lights in.....
Without the smaller plastic surround, you'll have gaps.
Old Aug 15, 2009 | 06:55 PM
Bobby_80s's Avatar
Axle/Gears: no idea
no i wont. i know what you mean but...
1. i have a knight rider bumper with turn signal blackouts. so that eyelid gap is gone kinda like the 91-92 bumpers.
2. i want the 91-92 headlights because the earlier big headlights are showing THROUGH the turn signal blackouts and in affect showing all teh hardware holding them on the bumper
so i want the smaller headlights with the trim so the headlight beam will be above that blackout body line and not through it but over it.
i'll post pics when i'm done cuz im not sure how else to describe it.
i can get the trim from 91-92 to fit. not easily but i'll make it work.
and i was just mroe concerned about the wiring but that question has been put to rest.
so wish me luck. i got 3 days off coming up this week so i hope to try it out then.
and as far as the metal frame/bracket i'll figure soemthing out either fabricate the smaller head luight to sit in the biggger metal frame from 86 or unbolt everything and bolt in the 91-92 frame and see what happens.
either way i will get these smaller headlights and trim to work for my car.
thanks guys
Old Aug 21, 2009 | 09:19 AM
Bobby_80s's Avatar
Axle/Gears: no idea
ok guys yesterday i accolmplished this task.
was fairly simple process. majority for everything just bolted in.
aligning the parts with the hood and fender wasnt fun and im still not 100% satisfied with the driver light as far as being flush with the hood but it got real dark and had to stop.
anyways heres 2 photos. i like the look and the light doesnt reveal the blackout hardware not nearly as much.
im happy with that.
plus the 91-92 headlight trim is perfect for the blackout setup. no having to cut the lip off the 82-90 style and sanding down and painting.
Attached Thumbnails 86 with 92 headlights?-img_3434.jpg   86 with 92 headlights?-img_4565.jpg
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
