Helpppp!!! 1990 RS Fender removal
Old Aug 23, 2009 | 04:56 PM
kellys1990RS's Avatar
Greetings all. I just started working on a 1990 Camaro RS with my daughter. We're trying to remove the fenders and can't quite get them off. On the passenger side we have everything loose except where the fender wraps under just behind the front wheel. It looks like there's a bolt holding it on but I can't see where someone could get to the head of this bolt to take it off. Any help would be greatly appreciated.
Old Aug 23, 2009 | 05:11 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: Helpppp!!! 1990 RS Fender removal
This is pretty much the case on every third gen. There is in fact a bolt there. Someone probably placed a jack there and bent the flange. You'll need to unbend it. It should be obvious which way to bend it. Use a pry-bar, locking pliers, and be careful not to dent anything.
Good luck
Alex
Old Aug 23, 2009 | 07:08 PM
Thanks a million novafirebird guy. That did the trick. I can't believe people do that. It was smashed flat.
P.S.: So much for thinking removing the fender would make it easier to get to the spark plugs.
Old Aug 23, 2009 | 08:15 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
easiest way to do it is to get the car on a lift..... u can do it with it on jackstands but its very uncomfortable
Old Aug 23, 2009 | 08:43 PM
Do a search on spark plugs on the general tech board and you'll find some good info on getting at those dam plugs. Hope the rest of your bodywork goes well.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
morrow
Jan 13, 2024 12:29 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
tgp1990
Sep 4, 2015 06:24 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
