window motor?
Old Aug 23, 2009 | 07:35 PM
eddie jr's Avatar
window motor?
The passenger side window suddenly will not go up, but it will go down just fine. WHen you try to put it up the lights dim and sometimes the pump re-primes (with the car off and key on). Is this typical signs of the power window motor going? I doubt it is wiring as the other works fine and i have not touched or disturbed anything and i checked the harness attachment to the motor.
Old Aug 23, 2009 | 08:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: window motor?
Might want to check the regulator and guide tracks the window moves in - maybe a bad roller or bent guide is keeping it from moving. Otherwise, search for the thread on "window motor ... bogus" and follow that - makes the install very easy, and it works great!
Here's the thread: https://www.thirdgen.org/forums/body...tall-easy.html
Old Aug 24, 2009 | 09:50 AM
1Aauto's Avatar
Former Sponsor
Re: window motor?
HI Eddie,
I'd get a test light and test the down power from the switch to the motor to make sure it's not the switch.
If it has power going to the motor,then the motors gone bad.
Here's a link to our window motor section too incase you need one.
Camaro Window Motor
Old Aug 24, 2009 | 01:34 PM
eddie jr's Avatar
Re: window motor?
thanks for the replies guys. I thought about it more and realized i had a spare switch, so i tried that this morning and no different. I then used a meter and am not getting 12v on the "up" wire at the motor and the lights still dim with the motor disconnected when pushing "up", so there must be some sort of ground between the switch and the motor on that wire only.
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
neekolzun
Aug 24, 2015 04:59 PM
evan555222
Aug 22, 2015 07:14 PM
