rattle in dash
Old Aug 24, 2009 | 07:27 AM
84z5350's Avatar
Car: 1986 z28
Axle/Gears: ?
rattle in dash
what would make my dash rattle and squeek when hitting bumps?does anyone else have this problem? ive tryed tightning bolts and screws but still does it
Old Aug 24, 2009 | 09:46 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: rattle in dash
Pretty much all third gens do this. I blame the plastic pieces rubbing againt other plastic pieces. Over time The plastic warps and causes rubbing. I think that installing little pieces of rubber or similar between mounting locations, would help a bit, but I havent tried it.
Old Aug 24, 2009 | 12:01 PM
toomany's Avatar
Re: rattle in dash
One of the bad things about cars from the 80's is the build quallity. Every 3rd gen I have owned/ridden in has had dash squeaks/rattles. Some cars a very noisy and others are somewhat quiet. Bascily the entire dash is made of plastic, it's going to flex with the car. Subframe connectors help a buch with this.
Old Aug 24, 2009 | 12:48 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Re: rattle in dash
Ive owned 2 IROCs--1 without subframe connectors and 1 with and I can tell you the one with the SFC is a totally different car!! NO rattles whatsoever--I highly recommend getting them if you are going to keep your car.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
