About to go NUTS taking this ground effect off!! help!
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, I've got a 91 T/A where I need to take off the ground effect running to both wheels (the center one). I've taken almost the whole thing off, but there's this last section right behind the driver's side front wheel that just won't come off. I took off all the screws. What gives?
Here's a couple pictures:
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: About to go NUTS taking this ground effect off!! help!
not sure about the birds but i know the camaros have nuts on the inside that you have to take off. take off the interior panel in that area and feel around on the back side.
Engine: LB9
Hmmm, well the part that is stuck is the one that's attached to the fender, no interior panels in there. I'm talking about the part in the first picture, I threw the second one in there just for the hell of it.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yeah, there are nuts. some behind the kick panel, you may have to remove the black rubber tape covering the hole in the chassis behind the kickpanel. The rear is the same deal, remove the panel that covers the seatbelt apparatus, remove the sticky black rubber thing and there is a hole in the chassis that you can get to the nuts through
Engine: LB9
What's a kick panel? sorry if that's a dumb question lol
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
set in car , move lt. foot to the left , the panel it touches is the kick panel . it can be a small PITA once its off , depending on options . anyway then you should then access the nuts . good luck .
Engine: LB9
OK so I did that but the only nuts I get to access are the ones holding the door hinges. After looking through it, apparently I have to remove the whole freakin' door to get those ground effects off because I was able to see nuts holding the screws from the ground effect on the inside of the front driver's side fender. If there's an easier way PLEASE let me know!
Car: 1985 Pontiac Trans Am
you need to remove the plastic inner fender then u can acess those nuts easily.
Car: To many to list
Engine: LB9
*gasp* so the door doesn't need to go?! And is the passenger side the same?
Engine: LB9
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Okay, look at the front tire, now, look all around it, theres a plastic panel that runs around the inside of your fender, its held on with small hex bolts, and some snap clips. Remove that plastic panel, and put your hand inside the fender, and feel around the spot that the GFX is caught on, and you should feel 2 small speed nuts.
Hope that explains it.
Engine: LB9
hahaha It is kinda late and I am a little tired.
Thanks for the tip... I'm glad I waited since today I was about to take the door off.
Car: 88 iroc camaro
Axle/Gears: stock
sorry man i thought we were looking at a picture of the rear. and I thought the second picture was showing the front already taken off. my bad, should have read more closely, good job figuring it out!!
Engine: LB9
Thanks for the help guys!
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
92firebirdchris
Aug 14, 2015 11:56 AM
