ttops leaks
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
ttops leaks
my cousin only replaced the drivers side t-top it looks like he forgot to put adhesive in the t-top channel that is by the windshield and the t-top weatherstrip. The t-top channel that is by the hatch side and the t-top weatherstrip.
water only leaks on my right rear seat
is there way to fix it?
Re: ttops leaks
I also had my rear hatch seal replaced
could it be also leaking from the hatch bolts
Re: ttops leaks
does any know how to fix this?
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: ttops leaks
Best thing to do is search "t-top leaks".There are several experiences & several personal fixes.
For example,mine leaked bad even after new stripping was put on.
I kept adjusting the pin guides til I was satisfied.
There are ppl who took stripping off & added caulking,RTV,& windshield sealer.
It depends on what you want//need//can do,& there's even a magazine editor installing stripping showing some tips along the way...
Check it out--
Check it out--
Re: ttops leaks
Check it out--
Check it out--
Car: '87 Camaro
Re: ttops leaks
For some odd reason I can't enter a link that can be clicked on.
Go to-
SuperChevyMagazine-
Click Technical Articles-
T-Top Blues is the article name.
This article deals with removing,cleaning,& installing new t-top stripping.
During the install,there are a few tips on where to put extra sealer in the most leak-prone areas.
Maybe this will help.
Go to-
SuperChevyMagazine-
Re: ttops leaks
Go to-
SuperChevyMagazine-
Go to-
SuperChevyMagazine-
Is this the link that you were talking about?
http://www.superchevy.com/technical/...rip/index.html
Re: ttops leaks
what tools do I need to repair my drivers T-Tops leak?
Re: ttops leaks
bump
